RV.Net Open Roads Forum: Travel Trailers: Do you store your TT level?
 > Do you store your TT level?
boosTT
Milwaukee
Posted: 04/26/12 06:38am Link  |  Print  |  Notify Moderator
When my RV is in the storage lot, I keep the hitch end a bit higher to allow water to flow down the back. Mostly because my front seal is only so-so right now (on the to do list).
Do you store your trailer level?
rcase13
Charlotte
Posted: 04/26/12 06:43am Link  |  Print  |  Notify Moderator
I don't because the last thing I want is water puddling on top. I leave it at a slight incline so water drains off faster.
2013 Jayco Redhawk 26XS
NanciL
Bakersville, NC, USA
Posted: 04/26/12 06:48am Link  |  Print  |  Notify Moderator
a bit highr in front, so they rain won't puddle
Jack L
Jack & Nanci
ExRocketScientist
Laurel, MD
Posted: 04/26/12 06:52am Link  |  Print  |  Notify Moderator
The roofs of my fiver is sloped so when level water won't puddle anywhere. The roof of my TT is radiused, so if level it won't puddle any too. With them level, it is no problem running the slides in and out. Right now, the fiver is a bit off side to side (I didn't bother leveling it when we returned home a few weeks ago because I knew I would be moving it again soon), and the slide doesn't like it one bit if you try to run it in or out.
ERS
Turbo Diesel Dude
Green Mountain, NC
Posted: 04/26/12 06:54am Link  |  Print  |  Notify Moderator
Mine is max nose high for drainage of water/snow melt.
charles weidman
CavemanCharlie
Storden,MN
I usually store mine in the shed so yes I leave it level. If it's outside I still usually leave it level because I like to start the fridge a day before I leave and the fridge should be level when it's running.
DE88ROX
West Michigan. The other West Coast
Posted: 04/26/12 07:47am Link  |  Print  |  Notify Moderator
Whatever height my TT is in the front from unhooking, that's where I keep it. The roof has a radius to it so water puddling shouldn't be a concern.
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
skipnchar
Topeka or somewhere else
Posted: 04/26/12 07:36am Link  |  Print  |  Notify Moderator
If you have a flat roof storing noise high or low is not a bad idea. with a radius roof it really doesn't make any difference. If you DO store it out of level then be sure you don't FORGET and fire up the fridge for a cool down without leveling first.
Chromag
Posted: 04/26/12 07:50am Link  |  Print  |  Notify Moderator
How much of an angle can the fridge handle? We've been firing up the fridge in propane mode the night before we leave so it'll be nice and cold.
I live in Florida - lots of sun - is puddling really an issue? I never really thought to leave it nose high. None of the TT's around me do that. They all look level to me.
2012 Crossroads Z-1 271BH
2004 Nissan Armada with Blue Ox BXW1500, Prodigy P3
Playtime II
No. VA
Posted: 04/26/12 07:51am Link  |  Print  |  Notify Moderator
Just nose high enough to clear the hitch ball to speed unhitching and hitching. Not any higher as I do not put down the stabilizers and I do not want the wind to rock the TT excessively and bend the tongue jack tube.
Playtime IV
2006 HR Scepter 42DSQ
