Sandia Man
Rio Rancho, NM
I get it somewhat close and do allow for rain or snow run-off, but not nearly as level as if we're camping. No worries on fridge as you have to be way out of level to affect operation with currently designed RV fridges.
Oasisbob
Portland Oregon 97266
I do store my HTT level as it is best for the fridge. I also have a covered area or I too would have puddles on my roof as well as it has settled. As if it would have taken longer for the manufacturer to put a steeper edge on the roof. Sheeesh. I see folkd storing their rigs sloped often here where we get lots of rain.
Oasis Bob
Wonderful wife & 4 Really Fun kids
2008 KIA Sedona 3.8L 24 valve V-6
2001 Bantam Trail Lite B-19
HAPPY TRAILS
301TBS
Ontario, Canada
Nose high for me too, the front downspouts drain onto the storage doors, and the back run clear of everything.
2012 Crossroads Z1 271B
2009 F150 4x4,4.6,3v. 6spd. 3.73/9.75
Reese dual cam
alexleblanc
Scoudouc N.B
mines somewhat nose high as its parked on a slope, the nose is down as far as it will and and there's still an incline. I plan on building a proper pad for it this summer like i had at the last house.
TV - 2011 F150 FX4 EB | Max Tow Pkg | LT285/55R20E1 Tires | Airlift Bags
TT - 2011 Dutchmen 295BHGS Bunkhouse
Tow equipment - Reese Trunnion style 1200/12000 bars w/Dual Cam HP Sway control
Alex ('84)
DW ('81)
DD1 ('09)
DD2 ('11)
TURBODOG1000
INDY
Slightly nose high, when stored under the carport and the same when camping, the way that Jayco made the roof I will have two puddles up near the front seam and trim when level, this is not much of a tilt, maybe half a bubble.
X2 on the front down spouts will drip across my forward storage doors.
I think that excessive tilt is a bad idea, instead of the water draining straight down and dripping off, it may run sideways and leak past seams that normally keep water out when vertical. (Slides??? Doorway???)
2005 F150 XLT Supercab LB Heavy Payload 5.4, 4.10
2007 Jayco Jayflight 31BHDS
Back-up camera on the TT with infrared & microphone
Prodigy
ScanGauge II
Reese duel cam hitch, U-bolt style ($40 at a garage sale)
2 canoes, 3 kayaks, & camping dog (Tootsie)
autorot8
N. CA
Stored level, but it is also stored inside protected from the elements.
F-350 towing a Prime Time Lacrosse 296BHS
"Overstating the Obvious rarely helps the Oblivious!"
sch911
Rochester Hills, MI
Chromag wrote: How much of an angle can the fridge handle? We've been firing up the fridge in propane mode the night before we leave so it'll be nice and cold.
DometicUserManual wrote: Leveling is one of the requirements for proper operation with
absorption refrigerators. To ensure proper leveling the vehicle needs to be leveled only so it is comfortable to live in (no noticeable sloping of floor or walls).
I try for about a half of a bubble....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
JoyceandSteve
Houston, Texas
When I stored outside without power, it was the in the position that released the coupler from the ball. Now I have it inside with power so I try to level it because I leave the fridge running all the time. It mught be OK to have a half a bubble off but I usually have it pretty near level. (I have friends a half a bubble off and they function???)
Steve & Joyce
2011 Chevrolet 2500 Z71 4X4
2013 Montana High Country 343 RL
1996 Celebrity 200 Boat
2000 Yamaha 1200 LTD Waverunner
2012 Ford Mustang GT (Mama's ride)
Vítejte na víkend doma a Steve Joyce
Techie
Pahrump, NV, USA
We always store ours level.
2011 Airstream Classic Limited 34'
2011 GMC Sierra 2500HD Duramax/Allison SRW
Follow our adventures
christopherglenn
a little over an hour from Yosemite
I park mine at home with 2 of the 6 tires on 2" cement pavers to level it side to side. If I don't plan on using it soon, I level it front to rear, else I leave it where it is when I unhook. My generators will run it's ac, which is nice when the power goes out around here.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
