Luke Porter
Not on the road :(
Did my first oil change on my new 3500. I found only 9 grease zerks. Thought there used to be 10?
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
therink
Rochester
I'm tuning into this thread. I'd like to know how many and where they all are.
Steve
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
Luke Porter
Not on the road :(
Guess I don't know what all of those things are.
Pretty sure my 06 had ten--got rid of that in 09.
Whatever the round bar that goes from side to side--had a zerk on the left hand side.
This truck doesn't have a zerk there.
redsb3
Tucson
Think there should be 11, at least that's how many my 05 has. Not to say they couldn't have done away with some. Found my notes
4 = Upper and lower ball joints.
2 = Outer tie rods.
2 = Inner tie rods.
1 = Idler arm.
1 = Pitman arm.
1 = Center link.
However a quick check of the Diesel Place forum says that from model year 11 on there are only 9, so apparently you got them all.
edited 04/26/12 07:13pm by redsb3 *
2005 GMC Sierra SLT CC/SB with 6.6L Duramax/Allison
2002 Automate 5W, 32 ft, 13,280 GVWR
Valley Glider Hitch
k1ngdlm
PA. , USA
11 on 2006. Go to dieselplace.com It has photos of locations.
2006 SILVERADO LT3 3500HD LBZ 4WD Crew
2004 PALOMINO MAVERICK M-1000-SL
38' racecar trailer W/ Dirt Late Model #
K1ng
Engineer9860
Eagle Scout dad
Yes, 11 is the magic number.
U/L balljoint L/R =4
I/O tierod L/R =4
Idler arm =2
Pitman arm =1
In Memoriam: Liberty Belle
redsb3
Tucson
Nope, your 06 had 11, the one is a real bear to see and get too. I bought an 18 inch flexible hose just so I could get that one. Used to have to bend it into a loop and feel the zerk with my hand cause I couldn't see it lying under the truck, just knew it was there.
Engineer9860
Eagle Scout dad
I always drop the front splash pan when doing a service on my trucks.
Makes getting all of the zerks a cinch.
racer4
Upstate New York
For those who like pictures, click this link.
You probably have sign in to see the bigger version of the pictures.
2007 GMC Sierra Classic Duramax/Allison CC LB Kelderman Air Ride
1998 SunnyBrook 30DB
scott1
CO
That is all well and good but that post is from 2005. I imagine it has changed in 7 years. So how many on a 2012?
