RV.Net Open Roads Forum: Running wires from solar panels
 > Running wires from solar panels
allnight
Bay Area, California
Posted: 04/26/12 06:55pm Link  |  Print  |  Notify Moderator
I've a couple of solar panels that I will be mounting on the roof. However, before doing that, I want to figure out where the wiring will go.
I'm wondering if there is a way to find whatever vertical tubes run through the walls. Anybody got any ideas? It would be great if I could run the wires down through one of them. I'm planning on the panels near the front of the roof, and the battery compartment is right behind the driver's seat and under the leading edge of the slide-out.
I don't really want to run the wires over the edge of the roof and into the the slide opening, but that is one option.
Anybody know how to find the tubes?
2004 Four Winds Fun Mover 39C (39' including 14' toy hauler garage)
Cat 3126E 300hp Allison MD3066P
Pics of the FunMover
Happy Prospector
The Great Sonora Desert
Posted: 04/26/12 07:25pm Link  |  Print  |  Notify Moderator
I ran my wires down thru a interior wall space. I went to roof and where the tank vents came up thru the roof, I had a space that wide to run my wires down to the utility area in my 5th wheel.
Kevin
Kevin
Retired, Fulltime RV'er
1999.5 F350 4X4 CC Diesel Flatbed
2007 Alpenlite Defender Toyhauler
2007 Yamaha Grizzly 700 (Green-It's your Daddy)
One Tough Kitty Named Bob
allnight
Posted: 04/26/12 07:32pm Link  |  Print  |  Notify Moderator
Yeah, that's what I did with the panel I put on my old truck camper. But, there's nothing like that on this unit...the only existing hole anywhere near it is a pop-up vent in the center (without power) and farther back is an A/C. Neither of those will help much, as I'd need to run the wires on the inside then, and it would be a much longer wire run.
harold1946
Surprise Arizona
Posted: 04/26/12 08:59pm Link  |  Print  |  Notify Moderator
By far the the easiest way is to run the wires down the refrigerator vent and over to the batteries.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer toad
SCVJeff
Santa Clarita, CA.
Posted: 04/26/12 11:43pm Link  |  Print  |  Notify Moderator
X2
Jeff - WA6EQU
stormbytes
Wherever I may roam
Posted: 04/27/12 03:17am Link  |  Print  |  Notify Moderator
That's how I did it. Gives you a straight shot into the coach or the underside, if you want to run further lengthwise with your wires.
SCClockDr
SC UpState
Posted: 04/27/12 05:39am Link  |  Print  |  Notify Moderator
A roof picture night help us see a potential solution.
George & Cathy
08 Titanium 28E33SA, XM, Honda EU 3000is, Trimetric, RotoChocks, LP Reg. Mod, PD 9260 Upgrade, 2 Gal Accum., WiFiRanger GO/Mobile/SKY
04 Ram 3500 5.9 DRW, PAC PRXB E/B, 4" MBRP SS Exhaust, Gauges, Aux Tank/box, BrakeSmart, Cobra (19).
USN Ret
AnEv942
CA
Posted: 04/28/12 03:04pm Link  |  Print  |  Notify Moderator
Agree Allnight-Refer top vent easist/cleanest route inside. Just looked at your pics on flicker site-you have a roof mounted refer top vent-thats the best way. Unfortunatly opposite side of your batteries-but just a longer wire run-so use the largest wire you can. Arrange panle(s) on roof to minimize wire on roof to vent (if you can).
smkettner
Posted: 04/28/12 03:36pm Link  |  Print  |  Notify Moderator
+1 on the fridge vent.
I used a two hole strain relief.
Strain relief (middle pic)
Link to solar install threads
675 watts solar
allnight
Posted: 04/29/12 06:09pm Link  |  Print  |  Notify Moderator
Here's what the roof looks like, driver's side on the left:
The batteries are straight down from the front left corner. They are in the front-most under-carriage cabinet:
I've got some 8-gauge wire that I was planning on using, but if I really have to route the wire across to the far side, then I'll probably want something bigger. Ugh.
