RV.Net Open Roads Forum: Truck Campers: Options for suspension
 > Options for suspension
Sabluka
Ak
Posted: 04/27/12 11:05am Link  |  Print  |  Notify Moderator
I've ordered the Rancho shocks and the Helwig sway bar.
Keep in mind that the 8-pac leaf springs on the truck, '88 GMC V3500 1-ton crew cab, are flat with the camper on the truck. Thats w/o any thing in the camper 'cept the LPG tanks and refrig.
My other additional options are;
1. Single leaf spring each side, rated at 1,500-lb each.
2. Air bags.
3. The RoadMaster Active suspension.
My instinct says new springs and then add the other if necessary.
What say you ace camper and suspension gurus?
Rick
kerry4951
East Central Pennsylvania
Posted: 04/27/12 11:14am Link  |  Print  |  Notify Moderator
Supersprings
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
ticki2
NH
Posted: 04/27/12 02:37pm Link  |  Print  |  Notify Moderator
I would go with your instincts , and then add regular overloads if you don't have them . A spring shop can build you springs to carry any weight you want .
'68 Avion C-11
'02 GMC DRW D/A
narcodog
Georgia
Posted: 04/27/12 03:43pm Link  |  Print  |  Notify Moderator
kerry4951 wrote:
Supersprings
X2
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 04/27/12 10:04pm Link  |  Print  |  Notify Moderator
Stableloads by Torklift.
Paul
Chief 2
Posted: 04/28/12 04:51am Link  |  Print  |  Notify Moderator
Spring shop for new springs capable of handling the load.
2005 Lance 1181 Loaded
2005 Chevy 3500 4X4 Duramax, Edge Attitude Tuner, 5" Exhaust, Airaid, Ranchos, Air Bags, Hellwig Big Wig
2007 38RL3 Mobile Suite
2001 Bass Tracker 185
gpascazio
Chicago
Posted: 04/28/12 06:58am Link  |  Print  |  Notify Moderator
Definitely a trip to the spring shop is in order, with the camper loaded on it.
2008 Ford F350 dually
6.4 L Diesel
2010 Eagle Cap 1160
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/28/12 06:15pm Link  |  Print  |  Notify Moderator
X2
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
SoCalDesertRider
SanDiego, CA, USA
X2
SoCalDesertRider
SanDiego, CA, USA
X2
