sin cal sd
Hooligan #109
Lady Fitzgerald wrote: sin cal sd wrote: Lady Fitzgerald wrote: mkirsch wrote: If anything airbags will make the problem WORSE because they add more "spring" to the mix.
X2. What is needed are better shocks. Springs absorb the bump/dip but it's the shocks that stop the bounce.
Im a little confused by these statements.
Airbags were invented for 2 reasons.
1. Equalize the load distribution.
2. Cushion the ride.
Wrong on both counts. Add-on air bags are variable overload springs that are designed to prevent rear end sag when under load. They do not equalize the load. They do not cushion the ride; if running anything more than the minimum air pressure required to prevent damage, they will make the vehicle ride harder unless offset by an added load.
No, i am right. They redistribute weight off the rear axle and put back on the trailer. And yes they do cushion the ride. Ask a semi driver the difference between air ride and springs. Oh im a semi driver. Thats what they are designed for. Just like air ride seats. Just like air ride cabs. Just like air ride fifth wheels. Air ride is for "absorbing impact" & "cushioning" the ride. They do in fact equalize load. By inflating them they put weight back on trailer axle equalizing the load, equalizing the load by shifting weight farther back.
Yes by adding air to the bags with no load, it will in fact be a rougher ride. I agree with you on that. Wasnt disputing.
My Pics
08 F-250 Lariat 4x4 CC
Wife and 2 Little Boys
nayther
Burbank, CA
Air bags definitely help cushion, air is a compressable fluid, therefore the bag does help soften the ride and if you raise the rear it shifts some of the weight off the rear to the trailer and front axle. I found the biggest benefit was getting my old truck off the big overload spring, that helped the ride a lot.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
dedmiston
Valencia
christopherglenn wrote: How do the airbags redistribute weight? I can see changing the vertical position of the hitch point, but I don't see how they could shift weight anywhere.
If it lifts up the tongue, then some of the weight on the trailer has to shift back, like lifting the handles of a wheel barrow.
2004.5 Dodge 2500 Diesel • 2005 Weekend Warrior FS2600 • Hooligan #3
Toys:
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
- 06 Yamaha TT-R90E
The Edmistons - Our Gallery
Never forget 9-11-01 Check out our blogs @ blog.rv.net
christopherglenn
a little over an hour from Yosemite
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
christopherglenn
Ok, so we are talking shifting what, 5-10 LBS..
Lifting a 20 foot wheel barrow 3 inches...
Crazy Cooter
Redding, CA
That is what I have been thinking this whole time about the weight shifting talk.
Tony KI6WAO
2006 Dodge Ram 3500 DRW
1992 Jeep Wrangler YJ
2012 Cyclone 300C
2013 Can Am Maverick X-RS
2006 KTM 525 EXC CA Plated
2008 KTM 525 XC ATV
2008 Polaris 525 IRS
2007 Kawasaki STX12F
2009 Kawasaki 260X
tvfrfireman
Portland, Or
rasteck wrote: The airbags made a noticeable difference for us. The worst stretch we've been on is 880 through Oakland and they helped a lot. Also getting both truck an trailer level when hitched up and EZ-Flex on the trailer has made a world of difference. I agree.. I put firestone air bags on with and air lift compressor and wireless system. I have a thirty six foot fifthwheel and the air bags eliminated the rebound bounce. Before the air bags I would hit a bump and it would keep bouncing three or four times with each rebound a little less. Now, I hit a bump and the multiple bouncing is gone.
crankshop1000
se michigan
The right fix is to add equalizer hitching with sway control.
Y-Guy
Tri-Cities, WA
crankshop1000 wrote: The right fix is to add equalizer hitching with sway control.
I'm pretty sure that won't do any good for a 5th wheel
Our RV: '07 Winnebago Sightseer 35J
Our Toys: Four Winns Horizon 190, Polaris Sportsman 500's & Honda Recon's
BigJon05
Central Valley CA
Air bags definitely quiet down the road bumps. They still happen but the bags stops the oscillating faster than just springs.
2007 3924 Raptor
03 F350 PSD longbed, 6" fabtec, BFG 35, airbags and compressor
09 Can-am Outlander 800 max xt ltd
07 Can-am Outlander 650 max xt
