bgant4
Naples, Fl
I would like to buy an owners manual for a 2008 duramax. I have the truck manual but not the one for the engine.
Thanks
82corvette
Southeast Nebraska
Go to www.helminc.com they supply the owners manuals to most automakers
ScottG
Bothell Wa.
Here you go, take your choice:
DuraMax manual
Scott, Grace and Wesly
H0NDA eu2000i
bigjettech
Bartlett,Il
Head over to the diesel place forum and ask. I'm sure someone has a pdf copy of the diesel supplement manual they would send you. I have an 06 so it's slightly different than yours.
2006 Silverado 2500hd duramax 4x4 - with a few mods
2006 Cherokee lite 285b+ 5th wheel
Allworth
Orlando, FL
Try E-bay. Or have any GM dealer order it for you.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
kernewek
Calgary, Alberta, Canada
Try here first GM Owner Center you need to register but should be able to get a digital copy of the duramax supplement for your vehicle
Good Luck
Kernewek
2006 Silverado 2500HD CC D/A 4x4
2007 Crossroads Zinger ZF27RL
"Just because I don't care, it doesn't mean I don't understand" Homer J Simpson
jalichty
Lander, Wyoming 82520
I have a silly question. I bought a Dodge Ram here a while ago and got an owner's manual with it and also a DVD titled Owner's Information. I am wondering how you access it in your truck if you are not carrying a laptop or other system to read it. If you don't have the laptop or other system, it seems to me to be pretty useless. When you talk about getting the PDF files, do you guys download them and print or just look them up when you need them?
John A. Lichty
elkhornsun
Monterey
You can go to the owner support section of chevrolet.com and to your truck and model year and all the manuals are available to download as a PDF - owner manual, Duramax manual, Allison manual, etc. and no need to login to anything.
Any Duramax manual up to 2010 will work for your truck.
I prefer a PDF anyway as it is faster to search for the information I need which is usually located in more than one place.
wintersun
Monterey
I use the digital version 100% of the time as it takes less time to search for the information I need. It is a PDF file so it can be read on any computer or even a tablet style computer.
The Duramax, Allison, and Silverado owner manual are all separate and I usually need to combine information from two or more to get a complete answer.
