RV.Net Open Roads Forum: 7 pin to charge TT battery while driving?
 > 7 pin to charge TT battery while driving?
DE88ROX
West Michigan. The other West Coast
Posted: 04/27/12 02:59pm Link  |  Print  |  Notify Moderator
JoyceandSteve wrote:
ScottG wrote:
Look at the little door over the plug on your Dodge. It has the pin-out embossed on the cover. Your Ram's charge wire is hot all the time whether the truck is on or not.
GM doesn't "turn on" the charge connection unless you ask them to or do it yourself. I have no idea why.
My last 2 GM trucks had it turned on? Same dealer so maybe the just do it in the prep?
I'm confused. How does one do this themselves. I just assumed it was always charging while plugged in.
I know that I had to hook up two hot wires that were already under the hood to the extra terminals on my fuse box. One was to power my P2 brake controller and the other went to the 7 pin in the rear bumper.
Is it safe to assume that is what you're talking about?
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
ScottG
Bothell Wa.
Posted: 04/27/12 03:32pm Link  |  Print  |  Notify Moderator
That's it! Plus I think you had to install a fuse for the charge circuit maybe?
Scott, Grace and Wesly
H0NDA eu2000i
DE88ROX
Posted: 04/28/12 09:48am Link  |  Print  |  Notify Moderator
Yeah I did. I believe it was either a 30 or 40 amp. dont remember.
rbell
Mi
Posted: 04/28/12 08:06am Link  |  Print  |  Notify Moderator
Measure the voltage on the trailer battery while the engine is off. Then measure it with the motor running at a fast idle. A fully charged battery will show about 12.7 vdc, If it's charging it'll go up to about 13.5 to 14 vdc.
Dick
rrev
Beatrice, NE
Posted: 04/27/12 08:25pm Link  |  Print  |  Notify Moderator
All you have to do is take a test light and see if you have juice at the #4 Pin in the connector. If you do, you're good.
