RV.Net Open Roads Forum: Toy Haulers: Electric water heater element??
Search only in Toy Haulers
 > Electric water heater element??
BIGDADDY650R
OVERBROOK, KANSAS
Posted: 04/30/12 10:58am Link  |  Print  |  Notify Moderator
check the fusable link??
2004 CHEV.2500 225/70R/19.5 , BD exhaust, and other goody's.
2004 40' KZ 3-SLIDE TOYHAULER
2007 RINCON
2008 RINCON
2011 RZR 800 LE. YELLOW(WHEN SHE LETS ME DRIVE IT!)
anitajeff
CA
Posted: 04/30/12 04:35pm Link  |  Print  |  Notify Moderator
My 2010 Cyclone 3010 has two switchs for the Electric hot water heater. The first inside, looks like a normal wall switch and yes it lights up. The second is a toggle switch with a pin to hold it in the OFF position in the water heater outside compartment. BOTH have to be ON with 110 V hook ups for it to work. I had a dealer in Alaska show me this works because I could not get it to work, and it is not in any the books. Once turned on it works good. And, Yes it is very easy to fry the element, must have water at all times or it is gone in seconds.
Dirtclods
Newport Beach
Posted: 05/02/12 02:46pm Link  |  Print  |  Notify Moderator
grizzly660fan wrote:
on suburban hot water heaters there is a reset you can do, open the cover on the outside, there are two black buttons you push them both at the same time.
2nd that!
Dirtclods
Newport Beach
Posted: 05/02/12 02:49pm Link  |  Print  |  Notify Moderator
IOWASTROKER wrote:
I have a '10 Cyclone 3912. I checked the continuity of element. OK
Switch is on in heater bay.
110-volt illuminated switch on panel inside lights up...so I assume it is getting power. No shore power today, so didn't check at element for 110 volts. No hot water. Any ideas??? Thanks in advance.
Who makes your water heater/Model?
