IOWASTROKER
rocky mountians
I have a '10 Cyclone 3912. I checked the continuity of element. OK
Switch is on in heater bay.
110-volt illuminated switch on panel inside lights up...so I assume it is getting power. No shore power today, so didn't check at element for 110 volts. No hot water. Any ideas??? Thanks in advance.
travelzoo
NW
What you are calling a 110 volt switch is most likely a 12 volt DC switch which trips a relay and supplies 110 AC to the water heater element. So just because the switch is lighted doesn't mean there is AC to the element.
Poppy & Nana
Upstate New York
This is a bad thought....but....are you sure you have water in the water heater???? Could it still be on winter by-pass?
Does it work on propane?
Leo & Kathy
Upstate, NY
in the Adirondacks
2013 Rubicon 2900 Toy Hauler
2008 - Ford F250 Super Crew 4x4
copeland343
Central Louisiana
On our water heater the switch and light inside is for gas, the light only comes on when gas does not light or runs out of gas. The switch for electric operation is outside under the water heater cover behind the gas regulator (small black switch)with no lights for electric operation. We have a suburban gas/electric water heater. Check your gas if you have a light inside on.
Deetour
Washington
Was there water in the tank when checking continuity? If so, its possible the water provided the path for your continuity reading.
Remove the element and if its burned out you'll certainly see it even before you can put a meter on it.
Kanyonkitty
Gerrardstown, WV
IF you even turned the electric element on for 6 - 8 seconds and had NO water in the tank, then you fried your electric element. You can get a new element at a place like Lowes.
IF heater not working on propane, first are you sure you even have water entering the tank? It's best to purge the air out of the gas lines before you attempt to light the heater. You can do this by lighting the burners on your cooktop for a minute or two. You should be able to hear the "burner" kick on to heat the water.
Deep wedgewood blue '99 7.3L PSD F-350 Super Duty crew cab long bed dually or wedgewood blue '97 F-350 7.3L PSD crew cab longbed SRW, Member: Sunlineclub.com Rescue a retired Greyhound, greyt calm low maintenance traveling companions
porknbeanr
Wildomar Ca. (Registered Wilbilly)
I drained mine for winter and neglected to refill. Plugged in to shore power to charge batteries and fried the element. The good news is it is easily replaced. FYI in our Cyclone the switch looks like an ordinary household wall switch and is separate from the Propane switch which is located on the control panel. It lights up red when on and your hooked up to shore power.
2008 CYCLONE 4012
2008 F350 SUPER DUTY
2007 ARCTIC CAT PROWLER SXS
1999 CLUB CAR
nayther
Burbank, CA
My old TH had an electric element with a switch next to it, nothing inside. I kept it off most of the time and only used it when I had hookups.
DIRT BIKES RULE
'12 Duramax CC short bed
'06 3005 Rage'n Falcon
garym114
Bluff Dale, Texas
No 110v, no hot water from electric element.
What is the question?
grizzly660fan
Utah
on suburban hot water heaters there is a reset you can do, open the cover on the outside, there are two black buttons you push them both at the same time.
2012 Epic Voltage 3905
2003 High Output Dodge Cummins
