RV.Net Open Roads Forum: Class A Motorhomes: Allison temperature after fluid change
 > Allison temperature after fluid change
Larry Cohen
Mobile, AL
Posted: 04/27/12 07:29pm Link  |  Print  |  Notify Moderator
On my first trip since Transynd/filter change, the tranny is running about 10 degrees cooler, even when compared to colder weather operation...my fluid had 30K miles
2006 Mountain Aire 43
Short haired wife, long haired daschund and 3 sugar gliders are co-pilots, along with Garmin Nuvi 855
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Whirlpool Residential Fridge !!!
capnqball
NW Oregon
Posted: 04/27/12 08:39pm Link  |  Print  |  Notify Moderator
I just had Transynd put in my duramax pickup and I noticed the same cooler temp immediately when I left the shop. Maybe it was worth the $375 after all.
belairbrian
Alabama
Posted: 04/28/12 08:28am Link  |  Print  |  Notify Moderator
edatlanta wrote:
My truck came from the factory with Dex VI and it has been changed by me including the spin on filter every 25,000 miles since new. My towing temps are barely higher than non-towing.
What benefits, if any, would I see from transynd?
here is the official answer from Allison Transynd Info
Several links at the bottom of the page. Bulletin 1099B explains DIY conversion.
The short answer is Longer fluid life, reduced temp (really only seen when towing heavy loads).
TV 2003 Chevy 3500 Crew Cab Dually w Duramax/Allison
2005 Keystone Cougar 314 EFS
Reese 16K Slider Hitch, Prodigy BC, Delorme GPS
USAF Retired
edatlanta
Panama City Beach, FL
Posted: 04/28/12 04:23am Link  |  Print  |  Notify Moderator
Ed
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, TTT/Schefenacker Towing Mirrors, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
belairbrian
Alabama
Posted: 04/27/12 08:47pm Link  |  Print  |  Notify Moderator
I saw the same thing when I did my truck. Mine came with Dex III. Alison syas 2 changes to get full benefits. I paid $220 for enough fluid for 2 changes and $16 for 2 filters. Nice having an Alison shop 2 miles from work.
othertonka
Stockton, CA
Posted: 04/27/12 09:25pm Link  |  Print  |  Notify Moderator
What type of fluid did you originally have before you changed to Transynd? Was it transynd or dexron?
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Sully2
Cincinnati
Posted: 04/28/12 09:41am Link  |  Print  |  Notify Moderator
Factory Transynd
So what did you base this 10 degree drop in temps on...a gauge reading???
2000 Country Coach Allure; Cummins ISC 330 HP; 71/2 - 8 MPG regardless
2002 Jeep Liberty
Larry Cohen
Mobile, AL
Posted: 04/28/12 08:32am Link  |  Print  |  Notify Moderator
Factory Transynd
