Grey Mountain
On the rez somewhere in Indian Country
I've been using a 50amp portable Surge Guard for about a year and a half; however, it appears to be belly-up. If I have to buy another, I'm considering a permanent install device. What are the pros and cons of each?
GM
Discovery 39S Tin Teepee
Honda CR-V Toad
Jeep Cherokee Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
Jim Cindy
Northcentral, PA
Ours is a permanent installation. I guess it's just my preference. I would however contact the manufacturer of your current unit and make arrangements to send it back for review and likely repair. Might just save a bundle.
PBH Portable Beach House
2008 GMC 2500HD Duramax Allison
2009 Cameo 34CK3
MorRyde IS, Disc Brakes, G614's
PullRite Super Glide Hitch
Propane fueled Yamaha EF 2400is
Grey Mountain
I have sent an email to Surge Guard Tech Support, awaiting an answer. If I have to replace the unit, I'm leaning toward an permanently installed device. Getting a bit tired of lugging the portable in and out when I hook up.
GM
CA Traveler
The Western States
The PI HW50C is an excellent unit with field replacable parts should you every have that problem. From available information it's better than SG.
Pros: Automatic, nothing to do once installed. The HW50C has a remote that displays V, A, HZ, error code and prior error code.
Cons: Installation including the data cable to the remote. In my rig it's installed w/o cutting any wires so removal is easy which is exactly what I did when I sold the last rig.
Prior error code use: You're out and about and there is low voltage. You're protected of course and then voltage returns to normal. You return and see the prior error code of low voltage and you are now more alert to the CG voltage.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
Jim Cindy
Northcentral, PA
I put mine in the compartment closest to the power inlet. I put new cable from the power inlet to the surge protector and spliced the cable going to the panel. Left enough extra wire to be able to bypass the surge protector in case of a failure. I carry the proper wire bugs and tape with my spare stuff.
hershey
Albuquerque,(fulltime) NM, USA
I can't think of any "con's" by having a permanent mount.
As for a portable? It could be stolen, even chained. Its out in the elements. It could be forgotten when leaving a site (ever forget your water regulator )
You could get lax and fail to use it on those quick overnight stays.
What did I leave out?
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
Dick_B
Palos Heights, IL USA
If permanent who will install it? Ours is permanent and I installed it.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
CA Traveler
The Western States
duplicate
edited 04/28/12 08:31am by CA Traveler *
jetenbu
Southeast Texas
I have a portable, have had it for years. Not chained. Never had a problem with anyone taking it. Maybe I am lucky. No problem hooking up as I leave it permanently attached to my power cable.
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
CA Traveler
The Western States
My installation. At HD I bought 2' of shething and wire and installed it in the unit. Mounted HW50C next to ATS. Removed cable from ATS and reconnected both cables. Drilled hole to route data cable. Note: On the current rig the supplied 14' data cable was not long enough. Ordered a 30' data cable online for $1.67 which included S&H - believe it or not. Note: The data cable looks like a phone cable but it is not as 2 wires are crossed. The data cable is available at various stores but hard to beat home delivery.
With this type of install the unit can be connected on the power cord input to the ATS or the CB panel output from the ATS. There are a number of posts on this topic and the basics are: Power cord install protects the ATS but the rig and ATS are not protected from a gen problem. Panel install does not protect the ATS but the rig is protected from utility power and gen. Relatively speaking the ATS is cheap. I've been on both sides of that discussion, but for this thread you have an option which is not available for the portable unit.
