Bob 66
dilley,tx
I'm looking for ideas on which satellite finder to purchase. I'm tired of using a signal finder and a satellite dish receiver.
donn0128
Pronounced Ore-gun
Alight a site works very well, but is expensive. There is also an app for smart pl
Hones that will allow you to pin point a clear location for your dish. I have both. Align a site I have had for several years and works very well.
Donn,Lorri,Max (The Rescued Lab)
Resident Know It All
Goldwinger
Mission, TX 78572
Birdog Meter will locate any satellite, and tell you when it is found.
You have to be a Friend to have a Friend.
'07 Winnebago Adventurer 35L
'07 Nissan Frontier 6cly PU
'04 Honda Goldwing
Hughes Satellite internet ~ Click to see where I at
Travel with NO PETS
TechWriter
Green Bay, WI USA
Bob 66 wrote: I'm looking for ideas on which satellite finder to purchase. I'm tired of using a signal finder and a satellite dish receiver.
What service Dish or Direct? And what dish model?
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
- Solar -- Solar Power
- Water -- Water Filtration
- Blog -- www.rvSeniorMoments.com
brirene
midwest
Assume you're referring to an automatic system. Dishnetwork Tailgater seems like a good one, if you go with DN. Only issue is that it is only compatible with one receiver at this time. (211k)
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
2oldman
Winchester WA
I think we need a bit more detail, I know I do.
powderman426
ohio
I helped a fellow camper aim his using the android app for satellite. What it does is puts the phone in a camera like mode and when you point it skyward, you can see the satellites by name. I held it up behind the dish and we had it aimed in a minute or two. If it were me, I would make a little bracket to hold the phone on the edge of the dish while aiming. I can't imagine it getting much easier than that except the Tailgater. That thing is awesome. Just drop it on the ground aimed somewhere near the southwest, and watch tv.
Ron & Charlotte
WD8CBT since 1976
28' Prowler & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
2oldman
Winchester WA
powderman426 wrote: I helped a fellow camper aim his using the android app for satellite. What is the name of this app?
donn0128
Pronounced Ore-gun
Dishpointer or for 20 bucks dishpointer pro.
powderman426
ohio
2oldman wrote: powderman426 wrote: I helped a fellow camper aim his using the android app for satellite. What is the name of this app?
Its called. Satellite AR
And its free.
So you wont see too many satellites at once, just select what service such as Dish, Direct, etc
