RV.Net Open Roads Forum: Truck Campers: Greenhorn question here
 > Greenhorn question here
THE REVEREND
san jose
Posted: 04/28/12 03:36pm Link  |  Print  |  Notify Moderator
Just relized that the fridge had a knob with three settings
electric gas & 12 volt. Now what I am thinking is gas is the propane. electric is when you plugged in / generator. And 12 volt is battery now is this correct? I only thought that damn fridge had 2 settings I guess I didn't turn the knob all the way
Thanks again
The Reverend
KD4UPL
Swoope, VA
Posted: 04/28/12 03:40pm Link  |  Print  |  Notify Moderator
You are correct. What you have is a 3 way fridge. Many RV's only have a 2 way fridge without the 12v capability.
Use caution if you select the 12v mode. It uses a lot of power! It will quickly drain a battery if the truck is not running. Even if the truck is running, depending on your wiring from truck to camper it may not keep up with the fridge. IMO it's kind of a useless setting. Propane works great. I think most of the people who use the 12v setting are just afraid of running propane while traveling.
louiskathy
Oregon (presently)
Posted: 04/28/12 04:21pm Link  |  Print  |  Notify Moderator
I'll add this since you said you were "green". The fridge needs a little 12v power to work even if it's set on 'gas'. So if you're batteries do go dead, and your fridge is on "gas"... and doesn't work...don't think it's broke.
Kathy
THE REVEREND
san jose
Posted: 04/28/12 04:30pm Link  |  Print  |  Notify Moderator
How long would the propane setting last? Longer than the battery?
Butch50
Bentonville, AR
Posted: 04/28/12 04:45pm Link  |  Print  |  Notify Moderator
Propane well last much longer than your 12V when not running your engine. It takes very little propane to operate your fridge.
Butch
2011 F350 KR 4X4 CC LB SRW
2012 Northern Lite 10 2 CDSE
2008 Custom Weld 17' Boat
2010 Can-Am 650XT Outlander Max
2012 Harley Tri Glide
fatmanobx
Russellville, Ar. Home Base
Posted: 04/28/12 05:25pm Link  |  Print  |  Notify Moderator
I leave my TC pluged in at home and the frig on elec. It's alway cold when I get ready to go. I switch over to gas just before loading and this has worked very well for me..good luck and enjoy your TC..
2003 Four Winds Infinity 37'
2011 Lance 855
3.5# Minpin named Darcy
Ford F250 Super Duty
AnEv942
CA
Yes day(s) cooling on propane and lil 12v for the controller,
verse hours running the fridge soley on 12v-
The 12v option intended only to be used with a charge source (while driving-engine running).
01 Ford 250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
fla-gypsy
North Florida
Posted: 04/28/12 09:11pm Link  |  Print  |  Notify Moderator
Most RV's only have a 2-way so kudos to you. Keep in mind that it may not work as well on some settings as others and that may be normal
Joners
Idaho Falls, Idaho
Posted: 04/28/12 08:39pm Link  |  Print  |  Notify Moderator
Mine has an "AUTO" mode which automatically selects the most efficient source. I leave my camper plugged into 120 Vac all the time that it is parked in the driveway. I start my fridge the day before leaving on a trip, or if needed at home, and have never had a problem. When plugged in at home, the battery isolator switch isolates the camper from the PU battery and there is no need to have the LP turned on. Prior to heading out on a trip, I turn on the LP tanks. Everything works as advertised.
Cap'n Bob
1996 Chevy K1500 4X4 Short Box, 5.7L Vortec, E rated tires, Lance Model 820 with Cabover Struts, Firestone Ride-Rite Air Bags, KYB MonoMax Shocks, Torklift Stable Loads, Happijac Truck Camper Tiedowns and Turnbuckles, Honda Eu2000i Inverter/Generator.
Bigfootchevy
Bancroft, Ontario, Canada
Posted: 04/28/12 09:16pm Link  |  Print  |  Notify Moderator
I also have the Auto mode. My fridge needs 12v power to work when its set on gas. When my camper is pluged into 120 in the driveway or at a campsite it doesn't need either the 12 volt or gas.
When your driving down the highway, you put it on 12 volt and gas. Your fridge should work fine. You are suppose to turn it off will filling your gas tanks.
Paul
