RV.Net Open Roads Forum: How do I measure for battery drain?
 > How do I measure for battery drain?
TimLoon
With the 4 Granddaughers in CT
Posted: 04/28/12 05:19pm Link  |  Print  |  Notify Moderator
Took the wife out the camper to start filling for the season. Put the key in the ignition and battery is dead, used the house batteries to get it started. Last time I used the MH was to take it for tires two weeks ago and everything was fine. Battery is one year old and was kept on a trickle charger inside all winter. Scan Gage shows alternator putting out 14.1-14.5 volts. Wife is sure I left something on. I have it on a charger and afterwards would like to determine if something is pulling the battery down in storage. Do I just take voltage readings each day with my meter? First trip is in two weeks and do not want any issues. Thanks, TIm
2007 Chevy Extended Cab, 4wd,6.0,
2008 Cougar 26RLS X-LITE
Chuck&Gail
In the Colorado Mountains
Posted: 04/28/12 05:58pm Link  |  Print  |  Notify Moderator
Actually you use an ammeter. Some clamp around the wire, cheaper models must be put in series with battery wire. Start on 10 amp range, just in case something is on. If nothing is turned on, current draw should be in milliamps. It will not be zero because of all the computer stuff on vehicles today, plus radio presets, alarm functions, autofob door locks, etc.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
marvh
Tampa area
Posted: 04/28/12 06:08pm Link  |  Print  |  Notify Moderator
(checking amp draw on a 12 volt system)
You Google these words and you will know everything that is needed to to check for battery draw down. The cable should be off the post for a couple of hours tho. Marvh
hohenwald48
Hohenwald, TN
Posted: 04/28/12 10:34pm Link  |  Print  |  Notify Moderator
Chuck&Gail,
I've never seen a clamp on DC amp meter. Any idea where I could get one?
2008 Fleetwood Jamboree 25G
1999 Jeep Wrangler
100% Solar Powered Home
When seconds count, the police are only minutes away.
rlking
Ojai, CA
Posted: 04/28/12 11:15pm Link  |  Print  |  Notify Moderator
Sear's has a couple of different DC amp-meters. Actually they are multi-meters, AC_DC volts, amps and, on the more expensive ones, they include resistance and temperature. Start around $50.00. AT least they did when I bought mine about 2 year ago.
TimLoon
Posted: 04/29/12 04:56am Link  |  Print  |  Notify Moderator
Thanks folks, time to update my multimeters.
Sea Dog
Ontario Can.
Posted: 04/29/12 08:32am Link  |  Print  |  Notify Moderator
My starting battery was installed in 1998.
Ford 460
After sitting in cold weather since Oct 1st,
The rig cranked over and started instantly,
as it has done each spring since, well, 1999!
Life is short,Death is long,
Take a vacation.
CampingJumble
San Diego
Posted: 04/30/12 10:24am Link  |  Print  |  Notify Moderator
Exactly.. As people have said you could buy something to test the draw on the battery.
hohenwald48
Hohenwald, TN
Posted: 04/30/12 12:57pm Link  |  Print  |  Notify Moderator
rlking,
I checked Sears and still can't find a clamp on amp meter that will read DC amps. Somebody please give me a model number or link.
Thanks
Ed9824v
Agua Dulce, Calif. 70 mi S.E. of Los Angeles
Posted: 04/30/12 01:44pm Link  |  Print  |  Notify Moderator
Craftsman Digital 400A AC/DC Clamp On Meter #82369 thats the one.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
