RV.Net Open Roads Forum: Attn: F-250/350 Owners with a sloppy PRNDL selector
 > Attn: F-250/350 Owners with a sloppy PRNDL selector
Steelhog
Harvest, AL
Posted: 04/28/12 07:00pm Link  |  Print  |  Notify Moderator
This a quick and relatively easy fix. The column mounted selector on my'02 F-250 was getting progressively looser and was starting to affect drivability. After some digging around on the web it appears this is a well know and very common ailment for many, many years of F series.
Under the dash at the end of the shift tube is a plate retained by two Torx bolts. These are prone to working loose. (One was literally hanging by a thread and the other just a few turns more) A few minutes on your back in the foot-well with some Locktite and a wrench will work wonders. If you want the whole package you can replace the two “shift tube bushings”. They are sold in pairs, Ford PN: F3TZ-7L278-A online for $5-$6 or at my local stealership for $16
http://www.ford-trucks.com/forums/804524-sloppy-gear-shift-lever-automatic.html
hallock5
Posted: 04/28/12 07:56pm Link  |  Print  |  Notify Moderator
Thanks, will put it my memory bank, if there is room.
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/29/12 09:00am Link  |  Print  |  Notify Moderator
I had to replace the plastic bushings for the shift rod on one of my F350's. Did those while I had the whole column apart and replaced just about everything since most of the wear parts were worn. I dislike working on tilt columns. The non-tilt column in my other F350 is much easier to work on.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
WyoTraveler
Northwest, Wyoming
Posted: 04/29/12 06:57am Link  |  Print  |  Notify Moderator
Yup, had the whole package replaced on my 02 F250. Ford people told me that it was such an inexpensive repair that they replaced all the parts new, including the cable etc. Ohman, shifts like a new truck.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
