RV.Net Open Roads Forum: Dinghy Towing: 1994 Grand Cherokee limited 4 x 4
Search only in Dinghy Towing
 > 1994 Grand Cherokee limited 4 x 4
rvgrammady
San Francisco Bay Area, California
Posted: 04/28/12 07:29pm Link  |  Print  |  Notify Moderator
I am trying to find out if this is a Jeep that can be towed
all 4 down or do I have to make modifications it's 8cyl. auto
199000 mi.
I'm looking for a tow car and have heard older Jeeps are good.
I have 97 Allegro Bay Gas '35.
any suggestions. alsos someone said Suzuki, Tracker,
I just want it for 2 years to take 3 long trips and go to
store or some sites.
Also, thinking bout renting a car but seems might be difficult
at some areas. only Enterprise picks up.
thanks 4 the help
35' 1997 Allegro Bay - No Toad Yet
"We'll be friends until I'm old and senile, then we'll be new friends."
gbopp
The Keystone State
Posted: 04/28/12 07:33pm Link  |  Print  |  Notify Moderator
Check the Remco Towing Application Charts.
sch911
Rochester Hills, MI
Posted: 04/28/12 07:41pm Link  |  Print  |  Notify Moderator
Most likely yes. If the transfer case has a neutral position then for sure 100% yes....
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
MCDDY
Louisiana
Posted: 05/01/12 09:24am Link  |  Print  |  Notify Moderator
We had an 02 Limited w/ V8. As said if the 4WD had 2 shift levers on the floor with the transfer case having a positive Neutral you can tow it. Just shift it to N and then put the tranny in D or R and if it doesn't do anything you're good to go. Put the tranny in P and the key in the Aux position. Next to our 1st toad, a 91 Honda Accord 5spd. it was the easiest to hook up and go.
Just remember the GC is heavy especially the limited, 5000lb.+ and you're driving a fairly large Gas coach. You will definitely need an auxiliary braking system for it.
I've said all the good things I know about the GC.
Good luck on your adventure
Dave
GEAUX TIGERS
Dave, Miss Sue & Lucy the Scotty
Big Easy Area.
FMCA 153192
2000 Monaco Windsor, 40' 2 Slide, ISC 350 HP.
2012 Honda Pilot or 1998 Blazer Toads
Aventa 2, Brake Buddy
