Well, I went out and checked the jumpers on the leveling card.
1. The diagram shows 4 sets of jumpers I only have 3 on my board.
2. All of my jumpers are fixed into one block of 3 pairs of holes.
3. I cut them apart and tried different settings and nothing changed.
It is a booger bear getting the lexan cover out of that gasket!
I guess I will see if HWH answers my email.
Well, this shows what happens when you do not know what you are doing. You do NOT cut them off. IF they were not removable, then they were OEM installed and a OEM board. The movable jumpers are used on replacement boards ONLY. You may just have to buy a new board now. Doug
Thanks for the comment. As it turned out nothing changed, nothing happened, and it still works the same. Backwards but still the same.
Edit
BTW the jumpers on my board are movable, but since the 3 jumpers were bonded together they were either all on or all off. They are now 3 separate jumpers all happily in their original places.
Edit
Have you adjusted the level sensor to turn all the yellow lights OFF?
