RV.Net Open Roads Forum: Hybrid Travel Trailers: wheel bearings
Open Roads Forum  >  Hybrid Travel Trailers
 > wheel bearings
hitman111
Missouri
Posted: 04/28/12 07:57pm Link  |  Print  |  Notify Moderator
how often do you check your wheel bearings
Chuck&Gail
In the Colorado Mountains
Posted: 04/28/12 09:00pm Link  |  Print  |  Notify Moderator
Ours is dual axle with EZ-Lube hubs. Every spring I lube three hubs using EZ-Lube. I then pull a forth hub to check brakes, bearings, and hand pack. That way I see each hub and parts once every 5 years.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
Chuck_S
Broadview Hts, OH, USA
Posted: 04/29/12 07:02am Link  |  Print  |  Notify Moderator
I don't doubt a longer period works for some or even many folks. I'm not willing to take the risk.
Dexter specifies 12 months/12,000 miles. From their FAQ:
E-Z LUBE - What is the E-Z Lube option?
The E-Z Lube option was designed specifically for the marine application where the axles are constantly being immersed in water. This feature provides a convenient method for purging the water from the hub cavity without having to pull the hub every time. The hubs should be removed every 12 months or 12,000 miles to inspect the bearings and it is imperative to replace the seal at this time to assure that the grease does not leak out the back onto the brake linings rendering the brakes non-functional.
(Emphasis added for those who dispute these are boat trailer axles and don't require annual maintenance. )
Bearing failure is directly proportional to the number of days the bearings are back-ordered in East Bubba where all breakdowns occur.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
justjjoe
Northern Illinois
Posted: 05/03/12 06:26am Link  |  Print  |  Notify Moderator
My Forest River dealer said that they should be re-packed every year and said he didn't care where I took it as long as I got it done. The local Jayco dealer told me every few years or so? aaarrggghhhhh
Dougie123
CT
Posted: 05/03/12 07:48am Link  |  Print  |  Notify Moderator
We only put about 600miles a year on our camper.
My guy told me do it every other year....and this is the year!
Dad - 44
Mom -
DD - 16
DD - 13
DS - 8
DS - 6
Dog - Irish Terrier
2010 Shamrock 233S
2011 Ram 2500 CC Laramie Hemi 4.10
Chuck_S
Posted: 05/03/12 05:01pm Link  |  Print  |  Notify Moderator
Every other year may be OK but at my first inspection it was noted the factory really hadn't properly lubricated the bearings and most of the grease was gone. Wheel bearings are certainly a weekend killer and may be a vacation killer. Season is too short for me to not do this annually.
-- Chuck
SLSAntigua
Pennsylvania
Posted: 05/04/12 05:49am Link  |  Print  |  Notify Moderator
My Bearings get checked every year during State inspection. I take the TT to a Trailer shop for inspection and work if needed. Need to be careful with Easy Lube (which I have) During inspection, they noted too much grease which can damage the bearing and seals. Explains why I have been seeing streaks of grease on the wheels.
Steve, DW, 2 DDs
2006 Starcraft Antigua 215SSO
2011 Chevy Silverado LT
Voyager Brake, Reese WDH and sway control
 > wheel bearings
