RV.Net Open Roads Forum: Travel Trailers: Hand held electric drill for jacks
 > Hand held electric drill for jacks
charlesmyatt
McAllen, TX, USA
Posted: 04/28/12 08:25pm Link  |  Print  |  Notify Moderator
Has anyone used a battery powered drill for leveling jacks?
I see the "tool" for sale in RV stores, but, need to see what size drill folks are using. One of the things I like about the trailer we are buying is that it doesn't have the "factory electric jacks" where one motor adjusts two jack legs.
What size and brand are you aware of? Leaving in four days to "meet" our new rig. Sadly, the Holiday Rambler I show as ours was damaged beyond reasonable repair by a hail storm. We're moving on and up.
fla-gypsy
North Florida
Posted: 04/28/12 08:32pm Link  |  Print  |  Notify Moderator
18V seems to be the most popular and the one I use
ed6713
FL
Posted: 04/28/12 08:35pm Link  |  Print  |  Notify Moderator
Your basic homeowner type drill will do the job. You probable own one now. You'll just have to have the right size socket then you're all ready to go. Sometimes a 6" extension is nice so you don't have to crawl under the TT to access the jack.
I just take the drill from the garage and bring it with me. Works fine.
Travel is fatal to prejudice,bigotry,and narrow-mindedness,and many of our people need it sorely on these accounts. Broad,wholesome, charitable views of men and things cannot be acquired by vegetating in one little corner of the earth all one's lifetime.
Helmsey
Knoxville, TN
Posted: 04/28/12 08:36pm Link  |  Print  |  Notify Moderator
I have an 18v Hitachi that I carry in the truck and use it almost every setup and breakdown. I'd say it is overkill, but isn't bigger always better?
KK4PFX
2010 Chaparral 322RLTS
2004 Chevrolet 2500HD D/A CCSB 4x4
Days camped in 2011: 22
Days camped in 2012: 34
Days camped in 2013: 6
sbowman871
Wilmington, Ohio
Posted: 04/28/12 08:57pm Link  |  Print  |  Notify Moderator
Most any cordless drill will work well. More volts in a cordless tool only means longer run time. Don't get caught up buying more volts, it will come with a bigger battery and will weigh you down. I use a 14 volt Hitachi, it works well as it only takes a few seconds per stabilizer. You will still want to do a final tightening with your hand crank wrench any way. Strip off all the grease from the jack threads. Keep it lubed with WD40, Blaster, or dry lube. Setting up will then be a breeze!
2010 Everlite 29FK
2011 Ford F150 V6 Ecoboost Max Tow 3.73
TenOC
On the road -- Full time
Posted: 04/28/12 09:07pm Link  |  Print  |  Notify Moderator
I have found that if you have a "high-speed" drill (I use a 110 Volt drill) it will (after a while) shear off the retainer pin on the jack's threaded rod. It has happen to me 4 time. I replaced the retainer pin with a larger - stronger pin. I have also use a battery powered impact wrench.
Now I have returned to manually lowering and raising -- I need the "work-out".
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
rydabyk
Florida Panhandle
Posted: 04/28/12 09:08pm Link  |  Print  |  Notify Moderator
Good old Sears 18 Volt drill. I take the charger with me when I go, no problems yet.
ata3001
Niagara Falls, NY
18v Dewalt & just set the torque setting to #6. No final hand tightening required. Torque setting on #6 on mine sets the stabilizers just right. I have an 18v because it's used for more than just setting the stabilizers.
Ron & BJ
2008 Dutchmen Freedom Spirit FS180 (24 FT) w/full factory dark tinted glass & front window
2007 Dodge Ram 4 WD, Quad Cab, Big Horn Edition, 5.7L Hemi w/tow pkg, 3.92 LSD, Prodigy
Chuck&Gail
In the Colorado Mountains
Posted: 04/28/12 09:20pm Link  |  Print  |  Notify Moderator
I use my DeWalt.
NOTE THOSE ARE NOT LEVELING JACKS, they are STABILIZERS. Folks have been known to bend TT frames trying to use them as levelers. You level side to side with Leveler Blocks under the wheels. You level front to back with the tongue jack. You then put down the stabilizers to keep the TT from rocking too much when you move around inside it.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
kcgaz
Scottsdale, Arizona
Posted: 04/28/12 09:54pm Link  |  Print  |  Notify Moderator
I use my 18v Coleman drill and it works great. I fashioned a J Hook that works great for job. Here is a Link to my blog that gives an overview of what I did. Hope this helps and it certainly beats hand cranking the jacks up and down.
God Bless,
Kevin & Tracy
1993 Fleetwood Tioga Arrow, 30', Ford 460...Still on the road!
My Blog
