RV.Net Open Roads Forum: Travel Trailers: Hand held electric drill for jacks
 > Hand held electric drill for jacks
Supercharged
Az.
Posted: 04/28/12 10:14pm Link  |  Print  |  Notify Moderator
If you get the 18V what will the wife have to do.
2005 Chev 5.3 Supercharged 395HP 425 T hp. Two wheels on front, 2 on back. one seat, tint windows. front and rear bumpers, headlights, windows. Door on each side. Heater, floor mats, 6 Reese candy bars, junk behind seats, some dirt. Pulls so hard.
tvman44
Southwest Louisiana
Posted: 04/29/12 01:44am Link  |  Print  |  Notify Moderator
18v Dewalt is what I have and use.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
ArticFox 676
West Melbourne, Florida
Posted: 04/29/12 06:38am Link  |  Print  |  Notify Moderator
Make sure you have a least two batteries. The wife has to hold her cup of coffee.
GuyM
The Great Midwest
Posted: 04/29/12 06:53am Link  |  Print  |  Notify Moderator
My old, old, old 12volt DeWalt does the job just fine.
willald
NC
Posted: 04/29/12 08:32am Link  |  Print  |  Notify Moderator
When we owned a TT, I used a 19.2V Craftsman drill, it worked great for years and years (never had a problem).
Not sure I agree that more voltage ONLY means longer running time. I have a Makita 9.6V cordless as well, and it would not move/turn the TT's stabilizer jacks at all. Had to step up to the 19.2V Craftsman model when we wanted one that would work the jacks.
One thing that helps a lot, IMO, is if you have a drill that has multiple 'gears', to let you select between low speed and high torque (what you want for this!), or high speed low torque. Our Craftsman has that, and it has obscene torque on the low speed setting.
Will
Uually
u.s.a.
Posted: 04/29/12 11:42am Link  |  Print  |  Notify Moderator
I use a 19.2 volt Sears works great
bartlettj
Forest Grove, OR
Posted: 04/29/12 12:13pm Link  |  Print  |  Notify Moderator
I was disappointed when I got the Camco socket because it doesn't have the 1/4" hex shank. I was going to use a cordless impact screwdriver, but the adaptor socket requires a drill chuck. Oh well, I picked up an extra 18V drill at Harbor Freight for cheap.
ewald628
NY
Posted: 04/29/12 01:23pm Link  |  Print  |  Notify Moderator
Chuck&Gail wrote:
I use my DeWalt.
NOTE THOSE ARE NOT LEVELING JACKS, they are STABILIZERS. Folks have been known to bend TT frames trying to use them as levelers. You level side to side with Leveler Blocks under the wheels. You level front to back with the tongue jack. You then put down the stabilizers to keep the TT from rocking too much when you move around inside it.
I am new to the travel trailer/RV world and this short description has made the difference extremely clear. To a newbie this is what I consider a golden information nugget. thank you
Terryallan
Foothills NC
Posted: 04/29/12 01:26pm Link  |  Print  |  Notify Moderator
Chuck&Gail wrote:
I use my DeWalt.
Correct. you level then just snug the stabs down. Not much power needed for that.
however. I needed a 24 Volt DeWalt to raise the Pup's roof, so I still use it.
Terry & Shay
Coachman Apex 288BH.
04 F150, 5.4, Lariat SuperCab
Lazy Campers
anaro
Mebane, NC
Posted: 04/29/12 01:44pm Link  |  Print  |  Notify Moderator
sbowman871 wrote:
Most any cordless drill will work well. More volts in a cordless tool only means longer run time. Don't get caught up buying more volts, it will come with a bigger battery and will weigh you down. I use a 14 volt Hitachi, it works well as it only takes a few seconds per stabilizer. You will still want to do a final tightening with your hand crank wrench any way. Strip off all the grease from the jack threads. Keep it lubed with WD40, Blaster, or dry lube. Setting up will then be a breeze!
x2. We bought a black and decker tool set at target to keep in the TT. It has a 14 volt drill, works great for the stab jacks.
As stated above, these are stabilizers, not levelers. We use these lynx levelers w/ lynx chocks that clip into them.
2009 Ford F250 Lariat Crew Cab 6.4L diesel 4WD
2011 Crossroads Zinger ZT26BL
Reese Dual Cam
4 nights camped in 2013!
21 nights camped in 2012!
27 nights camped in 2011!
