RV.Net Open Roads Forum: Class A Motorhomes: 454 oil capacity
 > 454 oil capacity
tonym2180
davie
Posted: 04/28/12 09:22pm Link  |  Print  |  Notify Moderator
I'm getting ready to do my first oil change in my 82 winnebago chieftain,I need to know how much oil the 454 takes. I've heard diffrent answers on how much it takes.... One was 5 quarts in the pan 1 in the filter . One was 6+1... I'm gonna use a 2 quart filter so I need to get it right. Any help would be appreciated being as I have no books or manuals.
yloshrk
Louisiana
Posted: 04/28/12 09:43pm Link  |  Print  |  Notify Moderator
Start with 6 and check dipstick, add if needed. There were different capacities for that motor depending on the size oil pan used for the application, but the base seems to be 6.
tonym2180
davie
Posted: 04/28/12 10:26pm Link  |  Print  |  Notify Moderator
The reason I'm asking is the old man has the wierdest cable looking dipstick with no marks on it so I have no idea where the level should be.once I figure it out I plan to mark it. It has an oil and tranny cooler so I figured 6 in the pan 1 in the filter but I planned on using the larger 2 quart so it would be a total of 8 quarts which would be easy to do since I'm using gallon jugs
3708
modesto
Posted: 04/28/12 10:38pm Link  |  Print  |  Notify Moderator
I had a 85 HR with a 454 and i used 7 Qts. at oil change and this was with a 1 Qt. filter. 3708
LVJ58
Las Vegas, Nevada
Posted: 04/28/12 11:50pm Link  |  Print  |  Notify Moderator
My old 84 Airstream with the 454 took 7 quarts with filter change..
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
D.E.Bishop
Eagle Rock, CA
Posted: 04/28/12 11:59pm Link  |  Print  |  Notify Moderator
I've got a 89 and it takes 7.5 quarts. Most places put in 6 and I tell them 7.5 would be better but they don't believe me until I start the engine.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
Brian in Michigan
S.E. Mi.
Posted: 04/29/12 05:03am Link  |  Print  |  Notify Moderator
7.5 on mine With the 2 quart filter
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS, Thorley Headers B&M trans cooler. Auto meter hooked to output of trans. Flowmaster mufflers recurved distributor Still Keepin on Truckin((((Was 7.5mpg Now 8.75mpg ))))
dalmationlovers
Port Orchard, WA
Posted: 04/29/12 08:47am Link  |  Print  |  Notify Moderator
My 87 Allegro 454 takes 7 Q. Thats how much it took last spring when I changed the oil and 1 filter. As usual I carry a quart or 2 just in case it needs a drink.
Gale Hawkins
Murray, KY
Posted: 04/29/12 08:50pm Link  |  Print  |  Notify Moderator
6 + 1 seems to be OEM standard.
WIX specs
oldduffer
Rapid City, SD
Posted: 04/29/12 09:15pm Link  |  Print  |  Notify Moderator
My 83 Chevy owners manual says 6 qts with a 1 qt filter. after starting it to check filter the oil is on the full mark.
 > 454 oil capacity
