RV.Net Open Roads Forum: General RVing Issues: Bathroom Tissue
 > Bathroom Tissue
Gottahaveit
Stockton CA
Posted: 04/29/12 11:07pm Link  |  Print  |  Notify Moderator
lol. Don't waste your $$$ on the RV paper
D.E.Bishop
Eagle Rock, CA
Posted: 04/29/12 11:49pm Link  |  Print  |  Notify Moderator
I only read the first page of replys so this may have been brought up already. Costco's Kirkland is suppose to be the worst of the TPs, funny thing is in our MoHo holding tank(not septic tank)it breaks down as we travel and most of the time "everything" is broken down and goes through our Sewer Solution hose which I believe 3/4". Haven't had to attach the flush hose on the road for three or four years. We did 10 weeks last fall and never pumped once just drain and rinse. I don't think it makes a darn bit of difference.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
1990 Bounder 27D
1995 Suzuki Sidekick 4X4
Stowmaster 5000
Ron3rd
Upland, CA USA
Posted: 04/30/12 06:50am Link  |  Print  |  Notify Moderator
brackleybeach wrote:
I was wondering if some of you have an opinion if we should be using RV bathroom tissue or if we should just use the same as we do at home.(cottonelle)
There's nothing magical about RV TP. Cottonelle works fine in RVs. We've used it in the past. Use the same stuff you use at home. Just use the tips posted above and you won't have any problems. We normally use Angel Soft which is similar to Cottonelle.
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
ryanallie1
Magalia, Calif
Hi All
We have been RV'ers for a liitle over 45+ years now. And we have always used what ever we buy for the house, Period
We have never had any issues either in all of these years. The only good thing that "RV Toilet Paper" is good for, is making your wallet a lot lighter, and the places that sell it, they laugh all the way to the bank. Don't be a Sucker.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
WeBeFulltimers
Here & There
Posted: 04/30/12 07:07am Link  |  Print  |  Notify Moderator
What difference does it make which tp you buy, you only use it once and then throw it away (I hope!)?
2007 DODGE RAM 2500 4x4 QC CTD 5.9 4SPD AUTO TIMBRENS PRODIGY REESE 16K KWIK-SLIDE***PACBRAKE PRXB 2012 MONTANA 3585SA
Dave H M
IL
Posted: 04/30/12 07:44am Link  |  Print  |  Notify Moderator
this brings to mind a post from way basck in which someone said to save the paper that you have used in a paper bag by the toilet.
Maybe I am making this part up but does it not make cute colors when you toss the stuff in the camp fire.
Turtle n Peeps
California
Posted: 04/30/12 08:19am Link  |  Print  |  Notify Moderator
Bet these are the same people that complain about odors and can't figure out where it's coming from.
outside the fire"
bill h
coastal reconquista
Posted: 04/30/12 09:17am Link  |  Print  |  Notify Moderator
The current Consumer Reports has a test article. WalMart had a brand that came out on top.
NOTE: Any incorrect spelling is intentional to prevent those annoying popups.
84 Barth 30Tag powered by HT502/Thorley/Weiand etc, Gear Vendors OD.
Siamese Calvin and Airedale Hobbes, 4WD Toyota toad
LarryJM
NoVa
Posted: 04/30/12 09:30am Link  |  Print  |  Notify Moderator
Turtle n Peeps wrote:
Toilet paper facts!!
OP, I have been RVing for over 45 years. Used any paper I could get my hands on. Never any problems ever.
X2 so that's 90 years
Larry
ALL TRAILER MODS>>ETERNABOND INSTALL>>RAINKAP INSTALL
restlesswind
Fulltime
Posted: 04/30/12 09:31am Link  |  Print  |  Notify Moderator
YES....You DO need to use the $$$ RV TP!
As well as RV tire air,RV fuel,anything that is used in or around the RV needs to be RV safe,tested and certified.
Anyone that believes all that will probably use the RV TV.The rest of us....well, you get the idea.
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
 > Bathroom Tissue
