Freela30
NC
My wife and I just bought our first RV. It's a 30' Coachmen Freelander. We have read that you should keep the humidity level below 50%. We are not sure what kind of dehumidifier we should get to keep the humidity low. Does anyone have a recommendation?
jetenbu
Southeast Texas
I do not use a humidifier. I have never felt the need for one.
Jim
RV: 2012 Montana 3625RE Quad Slide SKP#108921
TV: 2004.5 Dodge Dually 3500 HD
Favorite Quote: ''Life's tough, pilgrim, and it's even tougher if you're stupid.''-- John Wayne
Warning: THIS RIG PROTECTED BY SMITH AND WESSON!
U.S. Navy Vietnam Vet 1967-1968
christopherglenn
a little over an hour from Yosemite
You only (may) need one in the winter, the AC does the job in the summer. Get one that you can put on the counter, and has a drain hose to drain into the sink. Turn the bathroom vent on high (out/exhaust) when in the shower, make sure the blades are NOT turning when you flush. If you have a vent fan that exhausts outside, use it whenever cooking.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
tvman44
Southwest Louisiana
WE have one that you wen put on the counter top, and has a drain hose to drain into the sink. Makes a big difference. Ours is a 70 pint.
edited 04/29/12 07:08pm by tvman44 *
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
mockturtle
WA
I posted this past winter that I was very pleased with the Eva Dry 2200 dehumidifier I bought but it has now QUIT so I will retract that statement.
2000 Born Free 24RB Class C
6.8L Ford V-10 Engine, E450 Chassis
2002 Honda CR-V toad
Roadmaster Sterling A/T towbar
VIP braking system
Eddyline Merlin kayak
Kemahsabe
Kemah, TX
mockturtle wrote: I posted this past winter that I was very pleased with the Eva Dry 2200 dehumidifier I bought but it has now QUIT so I will retract that statement.
Check the power supply. That's usually what fails. I just got a PS on Ebay ($8). The Eva-Dry works well otherwise.
Queens Carriage
Treasure Coast, FLorida
120v 30 PT. dehumidifer amazon. use it in the winter.
Freela30
NC
Thank you for the advice. We have looked at the Eva Dry 2200 online and consider it if we need it.
mockturtle
WA
Kemahsabe wrote: mockturtle wrote: I posted this past winter that I was very pleased with the Eva Dry 2200 dehumidifier I bought but it has now QUIT so I will retract that statement.
Check the power supply. That's usually what fails. I just got a PS on Ebay ($8). The Eva-Dry works well otherwise. Would the power supply be likely to fail in 6 months??
Elizabeth24
Montreal
We have a 35 pint dehumidifer that we used on our trip to Montreal in 2010. We also used it once in Feb. in Yuma when it rained at night and everything was covered in dew the next morning. Ours is a Whirpool and was recently recalled and after much to do, we were finally given a brand new one. Although we don't use it often, we find it necessary in colder weather. We have a 25 ft Nash with storm windows and this helps keep the unit comfortable in colder weather.
