RV.Net Open Roads Forum: Tow Vehicles: Pressure Washing
Search only in Tow Vehicles
 > Pressure Washing
45Ricochet
North Idaho
Posted: 04/29/12 04:39pm Link  |  Print  |  Notify Moderator
Any of you guys (besides rollingrock ) use a pressure washer to clean your trucks and or RV’s ? I’ve always been the kind who don’t use car wash’s, ( like it would fit ) always done by hand.
Finally got around to getting one for the house and it sure seems like it could do some damage to a vehicle with improper use.
Any good, bad advice is appreciated.
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
bailer6334
Prescott, AZ
Posted: 04/29/12 04:51pm Link  |  Print  |  Notify Moderator
Yes, I use it on current and past vehicles & RV's.
2011 Arctic Fox 29-5T 5th Wheel
2011 Silverado HD 3500 6.6L Duramax Diesel Crew Cab
Short Bed 4X4 SRW LT
50gal Transfer Flow Aux. Tank
16K Valley Hitch w/bed saver
ib516
Up here!
Posted: 04/29/12 04:53pm Link  |  Print  |  Notify Moderator
Mine is a low (for a pressure washer) pressure model ~1800psi?, and I use it all the time on my truck and RV.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
robwen
NE OH
Posted: 04/29/12 05:09pm Link  |  Print  |  Notify Moderator
I have a 3000 psi model from Northern Tool. I use all but the zero degree nozzle on my vehicles and haven't done any damage. I would bet that the zero degree nozzle would cut paint and would definitely remove decals.
It works great on bugs and bird crap. It still is no substitute for a soapy mitt though, but it gets the heavy stuff.
Rob a.k.a 69oiler
'03 Ford Excursion V10 4x4 3.73 XLT
'98 SunnyBrook 30DB
'05 Continental Cargo 16'x8' enclosed 9950 GVW
Former Ford IDI and 7.3 PSD guy, hope to get back into a diesel someday.
therink
Rochester
Posted: 04/29/12 05:11pm Link  |  Print  |  Notify Moderator
I prefer a good detergent, soft bristle brush and garden hose. I would not use a pressure washer on my RV.
Steve Rinker
Rochester, NY
2013 Keystone Sydney 340FBH 5'er
2012 Silverado 3500HD, SRW,LTZ,4x4, Z71, Crew, 6.0 Gasser, 4:10 Gears, Standard bed
"These days, I have problems in areas that I used to not have areas", so life is good.
jim87vette
Arizona
Posted: 04/29/12 05:44pm Link  |  Print  |  Notify Moderator
I use one all the time no problems,just be smart about it?
08 GMC 3500 Dually Duramax
96 Chevy 2500 6.5
05 Yamaha Rhino
04 Gearbox 335FS 5er 14k wet
Beverley&Ken
Tottenham,Ontario
Posted: 04/29/12 06:16pm Link  |  Print  |  Notify Moderator
Use ours periodicaly, its only about 1500psi and never closer than about 12 inches, even further away around decals and openings. It is a good water saver.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
skipnchar
Topeka or somewhere else
Posted: 04/29/12 07:38pm Link  |  Print  |  Notify Moderator
I use them on the truck when traveling but don't EVER use them on the trailer. there are simply DOZENS of places that are sealed with caulk on an RV and those pressure washers have the ability to remove it EASILY if you hit the wrong place.
recycler
michigan
Posted: 04/29/12 07:58pm Link  |  Print  |  Notify Moderator
we (my family) have one that puts out is 4,000psi works great you just have to be careful with it will remove paint as easy as the dirt if you do it wrong
1968 franklin 11fk
93 d250 cummins
99 f550
RollingRockTX
Keller, Texas
Posted: 04/29/12 08:01pm Link  |  Print  |  Notify Moderator
Nice.
You can but turn down the pressure way down and never point the wand directly at the paint, this drives dirt and other contaminates into the paint..try to wash in a down angle away from the paint.
Best way to wash is always the two bucket method with a good car soap and quality microfiber cloth.
Most paint problems come from poor washing and drying. Using Cotton to dry is a major no no.
If you want more info, I can point you in the right direction. It may take a little investment, like 2 5 gal buckets, some quality MF's and some for drying you will be all set and looking all "rollingrockesk"
2006 Ford F250 King Ranch PSD
ARP Headstuds
ERG Delete
Diesel Site Coolant Filter System
Gearhead Performance Tuned, via XCALII, Edge Insight CTS
MBRP 4" Turbo Back, cat delete
MagHytech Rear Dif Cover
2011 Ford Expedition, HD Tow
2011 Cruiser CF33LF, KC5PFG
 > Pressure Washing
