RV.Net Open Roads Forum: Tow Vehicles: Pressure Washing
Search only in Tow Vehicles
 > Pressure Washing
UsualSuspect
Saugus, CA
Posted: 04/29/12 08:44pm Link  |  Print  |  Notify Moderator
I won't use a pressure washer, want to the keep the graphics where they are. I use Protect All Quick and Easy Wash, we have hard water and it does not leave any hard water spots that I can see.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC
2011 Toyota Tundra
Gone but not forgotten, 2008 Jayco 299 RLS
bovellois
La Pocatiere Canada
Posted: 04/30/12 11:40am Link  |  Print  |  Notify Moderator
skipnchar wrote:
I use them on the truck when traveling but don't EVER use them on the trailer. there are simply DOZENS of places that are sealed with caulk on an RV and those pressure washers have the ability to remove it EASILY if you hit the wrong place.
Especially when you look at the (non existant) seals around clearance lights. Grrr!
Bruno, Carol, Thierry and Julien
Sankei the fox terrier
Starla the Gordon setter
97 Dodge 2500 4x QC diesel
2006 ROO19
bartlettj
Forest Grove, OR
Posted: 04/30/12 03:16pm Link  |  Print  |  Notify Moderator
I had my dealer caulk those as part of my "little stuff" warranty work. Some of them were caulked from the factory and some weren't.
I caused the center seam of the popup I used to have to fail by pressure washing it. It had an aluminum textured roof (like a fridge) and that was the only way I could get the crud out of the texture. It was fine after I recaulked it, but that was not a pleasant weekend.
captainjohn2008
Ontario
Posted: 04/30/12 08:10pm Link  |  Print  |  Notify Moderator
I use mine in the winter only to remove the heavy stuff up here in the "Great White North". Have to be careful though as I'm sure mine would do damage if you used the wrong nozzle,pressure etc.
summithmk
butt#$%$ egypt, NV
Posted: 04/30/12 09:40pm Link  |  Print  |  Notify Moderator
45Ricochet wrote:
Any of you guys (besides rollingrock ) use a pressure washer to clean your trucks and or RV’s ? I’ve always been the kind who don’t use car wash’s, ( like it would fit ) always done by hand.
Finally got around to getting one for the house and it sure seems like it could do some damage to a vehicle with improper use.
Any good, bad advice is appreciated.
You can always test the pressure by pointing it at your face. I also recommend turning the pressure to the max and straight streaming the radiator, and intercooler stack to remove bugs.
 > Pressure Washing
