crouseman41
Blanchard ok
My insurance company is forcing me to change to either an Accu-check or One Touch Glucose Monitor, or pay significantly more for my current brand of test strips - I've used the same meter for 7+ years, so I know the new ones will be a lot different. I would like to hear from anyone who uses either of these meters regarding simplicity of use, correctness of readings, etc. I don't need a meter that talks to me or one that will do everything but let the cat out - just a simple to use, reliable, meter.
Thanks for any input.
Paulette
Dale & paulette Crouse
xcopiertech
home
I have used One-Touch for 13 years and if you have a problem, they will overnight you a new meter without any questions after talking to them on the 800 line
Poppy & Nana
Upstate New York
I use One Touch - as accurate as any other meter and very easy to read!
Leo & Kathy
Upstate, NY
in the Adirondacks
2013 Rubicon 2900 Toy Hauler
2008 - Ford F250 Super Crew 4x4
Sandia Man
Rio Rancho, NM
My DW is a nurse, she has used both meters on patients and found both to be quality units and are widely used by hospitals and Diabetics.
Beverley&Ken
Tottenham,Ontario
My wife has used the Accu-Check brand for at least 10 years, no problems. Periodically when she had blood work done, she and the lab will compare the readings from her Accu-Check to the actual lab work, they have always been the same or very close.
Beverley and Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
dbbls
Missouri
I am satisfied with my One Touch. A very fast machine. I understand you should get a new meter every 3 or 4 years.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
KCFDCapt
At Home
I have several One_Touch meters. I keep them in various places, work, FW, Shop and my desk at home. Five seconds from touching the blood to getting a reading. Very accurate and easy to use.
I would choose One-Touch if I had it to do all over again.
RockDodger
Northeast Illinois
I use Accucheck meter with the drum simply because I drop the dang strips on the floor. I have used it now for about ten years. I replace the battery every two years. No problems at all.
Terry & Marsha
2007 Toyota FJ Cruiser, V-6, 4WD
1987 Sunline Satellite, 20', Reese anti-sway
Northeast Illinois
frmAloha
Oregon (OR-y-gun)
I also use One Touch and have found it to be accurate and easy to use. And if you ever have questions about your meter, their customer service is very friendly and helpful.
Oregon Native
Retired w/
2000 31' SurfSide
Class A
crouseman41
Blanchard ok
Thanks for all the good info - based on your input and tutorials I watched online, One Touch it will be.
Paulette
