RV.Net Open Roads Forum: Class C Motorhomes: plastic rear window magnifier
 > plastic rear window magnifier
cac43
mo
Posted: 04/29/12 05:04pm Link  |  Print  |  Notify Moderator
Are there any tips how to keep the square plastic "magnifier" to stay in the rear window of my class c? I'v tried cleaning the window, wetting it and the plastic square pressing it in place per the directiioons on the packaga, but it falls off before very many days. I'v tried using clear packing tape around the edges but the heat loosens the tape and the square falls off again.
thanks for any tips.
safeman
McKinney TX
Posted: 04/29/12 05:12pm Link  |  Print  |  Notify Moderator
I have had three of these and have never had a problem with them getting loose. I replaced mine because they started to yellow.
Just a thought...there is a smooth side and a rough side, the smooth side goes toward the glass.
Maybe someone else will have a solution.
ronfisherman
SE Michigan
Posted: 04/29/12 05:14pm Link  |  Print  |  Notify Moderator
Mine has been on the inside of the rear window for 4 or 5 years. Just followed package directions with no problems.
Kodiak Chassis Class C Forum
bargeman
Chesapeake, VA
Posted: 04/29/12 06:04pm Link  |  Print  |  Notify Moderator
Ours has been in place for 8 years without any problems.
2002 Gulf Stream Conquest
04 Ranger Edge Toad
Sea Dog
Ontario Can.
Posted: 04/29/12 06:18pm Link  |  Print  |  Notify Moderator
Are you sure the glass is clean?
I have never had a problem after getting the bubbles worked out.
Life is short,Death is long,
Take a vacation.
W4MBG
Williamsburg, VA
Posted: 04/29/12 06:26pm Link  |  Print  |  Notify Moderator
No issues here either. Make sure "TOP" goes towards the top.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
cac43
mo
Posted: 04/29/12 07:05pm Link  |  Print  |  Notify Moderator
DUH!!! last few times I've been putting the wrong side to the glass.
Thanks!
ronfisherman
SE Michigan
Posted: 04/30/12 04:20am Link  |  Print  |  Notify Moderator
For those wanting information on how to install Fresnel rear window wide angle lens.
How to install.
* Apply the quality lens to the inside of the rear window near the bottom edge.
* Make sure window is clean, then wet it with water
* Apply smooth side of lens on the inside of window
* Remove air bubbles from the lens
* Hold firmly in place for a few seconds.
* The lens will turn crystal clear until be peeled off.
Harvey51
Alberta
Posted: 04/30/12 11:15pm Link  |  Print  |  Notify Moderator
How does it work? Does it make a rear view mirror useful?
2004 Adventurer (Canadian) 20 footer
ronfisherman
SE Michigan
Posted: 05/01/12 02:51am Link  |  Print  |  Notify Moderator
I use the rear view mirror and rear window wide angle lens to view my toad. Also helps to see when it's clear to change lanes.
