RV.Net Open Roads Forum: Beginning RVing: Dewinterizing?
 > Dewinterizing?
BeanMan
colorado
Posted: 04/29/12 05:48pm Link  |  Print  |  Notify Moderator
I'm pretty new to the RV world, I added RV antifreeze to the pressurized part of the water system last fall, not the water tank. To prepare it for use I should fill the water tank, pressurize, and wash the antifreeze out opening all the faucets etc doing a normal type of flush? Is it really that simple?
The previous season, when we bought the camper, it had just been blown out so I flushed the water system out but it didn't have antifreeze.
Thanks,
Fred
hyattjlbb
Minot, ND
Posted: 04/29/12 06:00pm Link  |  Print  |  Notify Moderator
Fill your tank with bleach/water mix and run through the lines. Let sit over night then drain it all. De-winterized and sanitized.
2011 Jayco Eagle 365BHS
2007 Chevy Silverado CC/SB 2500HD, Max & Alli
Beautiful Wife of only 17 Years
Boy - 15yrs, thinks he's 20
Boy - 8yrs
brirene
midwest
Posted: 04/29/12 06:10pm Link  |  Print  |  Notify Moderator
I agree, but would drain as much antifreeze as possible first by opening the low point drains and a faucet. Then fill the fresh water tank, adding 1/4 cup household bleach for every 15 gals of tank capacity, including your water heater. Run pump and open each faucet until you smell bleach, then let sit for several hours or overnight. Don't forget to fill the heater tank. Drain, flush with another tank of water. Ready to go.
'04 Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC Lariat 4x4 DRW 4.10 LB B&W Companion Edge Insight CTS
“The trail is the thing, not the end of the trail. Travel too fast, and you miss all you are traveling for.”
-Louis L'Amour
handye9
Park City, IL 60085
Posted: 04/29/12 06:11pm Link  |  Print  |  Notify Moderator
About 1/2 cup bleach, pour it into fresh water holding tank, then fill the tank with water. Pressurize the system and run water through toilet and all faucets until antifreeze is flushed. Turn off pump and let it set over night. Next day, drain and flush with plain water.
I see brirene types faster than I.
Check out my mods
08 F250 Crewcab,4X4, SB
5.4, 4.10 gears
Flowmaster exhaust, SCT tuner
12 Flagstaff 831FKBSS (TT) and 00 Maverick 8801 (TC)
Wife and I
USN MCPO (E9) Retired (active duty 1973 - 1995)
Magblue10
Valparaiso, IN
Posted: 04/29/12 07:18pm Link  |  Print  |  Notify Moderator
how do you fill the heater tank
brirene
midwest
Posted: 04/29/12 07:43pm Link  |  Print  |  Notify Moderator
First make sure it's not bypassed by making sure any valves in and/or out of the tank are open. If there is a third just in front of the tank running between the two lines, close that one. Then you can run the pump and either open a hot water valve or open the pressure release valve on the heater. The tank will be full when you get a solid flow of water with no spitting (or when water comes out of the pressure relief valve).
CincyGus
Cincinnati
Posted: 04/29/12 07:51pm Link  |  Print  |  Notify Moderator
Often the bypass valves for water heaters are behind a panel hidden on the back side of your water heater. If it's not in the vented area, thats where it likely is.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
seattlefirervr
Snohomish, WA
Posted: 04/29/12 08:11pm Link  |  Print  |  Notify Moderator
Good advice by all, just finished my annual dewinterizing. I would like to add a few more steps.
If you used RV antifreeze:
1. Fill freshwater tank with water/bleach ratio of 15 gallons to 1/4 cup bleach.
-add bleach early to assist mixing with water (especially if you dewinterize stationary)
2. Fill your lines with previous made water/bleach mixture, via onboard pump, by opening all valves sink(s), shower, etc.. Each line should take appoximately one quart of discharge to ensure proper filling. Make sure you open all your hot water valves and long enough to ensure you have pumped enough mixture thru your hot water heater. (average hot water tank is 6 gallons) With the proper ratio, you should notice a faint bleach odor on discharge.
3. Let this mixture sit for several hours or overnight. Think like a good "marinade"!
4. After "marinade" drain freshwater tank and hot water tank.
5. Refill freshwater tank and hot water tank.
6. Open up all lines and flush liberally making sure to open hot and cold water lines.
7. Repeat step 5 one more time and go camping!!
2006 31' Wildcat QBH,Yamaha 3000EFi Generator
2000 Ford F250 Lariat PSD CC,SB,4WD,AT. aFe Megacannon Airfilter,4" Diamond I exhaust,Custom"Evergreen Diesel"chip,Autometer pillar gauges,BD Torque Converter,ATS Turbo Housing,Wicked Wheel,BD Exhaust Brake,
 > Dewinterizing?
