RV.Net Open Roads Forum: Tech Issues: Vent fan
 > Vent fan
campinrooter
Middletown,Ohio
Posted: 04/29/12 07:37pm Link  |  Print  |  Notify Moderator
My fiver vent in the bedroom has wiring looks like for an additional air conditioner how can you hook a fan like you have in the bathroom dont want another air conditioner but a reversable fan would be great any help out there Thanks
skipnchar
Topeka or somewhere else
Posted: 04/29/12 07:40pm Link  |  Print  |  Notify Moderator
You would probably want your fan to operate on 12 volt power and if your wired for an air conditioner it would be 120 volt AC power.
NickT
Regina
Posted: 04/29/12 11:31pm Link  |  Print  |  Notify Moderator
Fantastic Fan has 120v units available. I have one, used it in just this situation. Mine only exhausts.
05 Hornet 275RLS
06 GMC Duramax
Dusty R
Charlotte Michigan 48813
Posted: 04/30/12 06:54am Link  |  Print  |  Notify Moderator
We had an '88 mallard that had a wire at a vent for 120V AC. I moved cable/wire from the 120V ac side of the panel to the 12v dc side, then added a 12v dc fan in the vent.
Dusty
ryanallie1
Magalia, Calif
Posted: 04/30/12 08:03am Link  |  Print  |  Notify Moderator
Hi All.
Over the many years as RV'ers, we have noticed that most Vents had a Ceiling Light very close to the Vent. If your sure you don't have any 12 volts up there now, test with a Multi-Meter. Then if not, just Piggy-Back the Ceiling Light for your power.
I have done that with quite a ferw different RV's over the years. Its very simple in most cases.
Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
pkunk
Questa, NM
Posted: 04/30/12 08:25am Link  |  Print  |  Notify Moderator
I just took out the rear air in my MH and used the 120v wires to power the Fantastic Vent by disconnecting them from 120v at the fan selector switch and making a jumper to a 12v fuse. Didn't have to drill & fish new wires and it's reversible back to 120v if a rear air is ever added.
1999 Coachman Mirada 34 ft.V10-F53 chassis
12ft.LR slide-2 gp31 AGM 12V @220AH
 > Vent fan
