RV.Net Open Roads Forum: Hybrid Travel Trailers: Do I need weight distribution?
Open Roads Forum  >  Hybrid Travel Trailers
 > Do I need weight distribution?
Spentcase
Posted: 04/29/12 07:56pm Link  |  Print  |  Notify Moderator
2004 silverado 2500LD - 2005 jayco 23b
I have sway control but was wondering about weight distribution. Do I need it? If so, point me in the right direction.
Thanks.
Oops...wrong forum...don't know how to move.
mike4947
N. Syracuse, NY
Posted: 04/29/12 08:26pm Link  |  Print  |  Notify Moderator
moved from folding trailer forum
wolfcat1
Vidor, Tx.
Posted: 04/29/12 09:12pm Link  |  Print  |  Notify Moderator
What part of Texas??
wolfie
seattlefirervr
Snohomish, WA
Posted: 04/29/12 09:26pm Link  |  Print  |  Notify Moderator
I would put weight distribution as a priority before sway control. Especially with just a 23' TT.
2006 31' Wildcat QBH,Yamaha 3000EFi Generator
2000 Ford F250 Lariat PSD CC,SB,4WD,AT. aFe Megacannon Airfilter,4" Diamond I exhaust,Custom"Evergreen Diesel"chip,Autometer pillar gauges,BD Torque Converter,ATS Turbo Housing,Wicked Wheel,BD Exhaust Brake,
Golden_HVAC
Fulltime, CA, USA
Posted: 04/29/12 09:52pm Link  |  Print  |  Notify Moderator
Hi,
It depends, how heavy is the trailer? Almost any popup trailer does not have enough hitch weight to need weight distribution, and the frame is not strong enough to handle the stress that weight distribution puts on the hitch coupler. Yet a travel trailer with a 2-5/16" ball probably has enough hitch weight that you are exceeding the "Average" hitch weight rating on the pickup of 500 pounds deadweight. Sure it will not damage the hitch for a while, but sooner or later, you will find out that the hitch is not strong enough.
The rating on your hitch might read 5,000/500 deadweight and 10,000/100 hitch when using a weight distribution system.
So if the trailer is over 5000 pounds total weight, or over 500 pounds on the hitch when loaded up for camping, then you need the weight distribution system.
Fred.
ArcticDodge
Sammamish, WA
Posted: 04/29/12 11:39pm Link  |  Print  |  Notify Moderator
I'd be using the WD long before the sway control.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
Chuck_S
Broadview Hts, OH, USA
Posted: 04/30/12 04:55am Link  |  Print  |  Notify Moderator
The Jayco 23B is actually tongue light. You'll need to find a way to load heavy stuff forward to get at least 10% of the weight on the ball. This trailer definitely needs sway control because of the poor weight distribution.
If loaded right this trailer should have at least 500 pounds on the ball. Open the tailgate and get a couple of your college football buddies to sit on it and note the suspension compression.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
Helmsey
Knoxville, TN
Posted: 04/30/12 07:00am Link  |  Print  |  Notify Moderator
1st thing to check when deciding on the need for a WD hitch.... check the label on your hitch. It should tell you how much weight it is rated for with and without weight distribution. If the tongue weight of your trailer is greater than the rated weight of your hitch without using the weight distribution, you need it.
KK4PFX
2010 Chaparral 322RLTS
2004 Chevrolet 2500HD D/A CCSB 4x4
Days camped in 2011: 22
Days camped in 2012: 34
Days camped in 2013: 6
Jayco25E
PA
Posted: 04/30/12 09:43am Link  |  Print  |  Notify Moderator
My rule of thumb is any RV bigger than a popup should have weight distribution and sway control.
2008 Chevy Avalanche
2005 Jayco 25E HTT
2 retired Greyhounds
PAThwacker
East Stroudsburg, PA
Posted: 04/30/12 11:06am Link  |  Print  |  Notify Moderator
How about a 21RBH 5000lb gross with 3500 srw?
2008 Starcraft Travelstar Sport 21RBH
2008 Chevy Trailblazer V8 3.42/ 2004 k2500 Suburban LT 6.0, 3.73, g80 locker, center buckets, and sunroof.
Me, DW, dd08, dd12, 88lb black lab!
