RV.Net Open Roads Forum: Class A Motorhomes: NEED HELP
Gulfstream 8378
Pleasant View
Posted: 04/29/12 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
We have a dometic fridge that the freezer is getting cold in but the bottom will not get cold any ideas? I have medicine that I have to keep in the fridge and it will not stay cold. We can't go on anywhere until I figure this out. All the recalls have been done and I was told everything was good to go. Turned it on today and the freezer works fine but not lower fridge? Also this is on a class A Gulfstream coach if that helps. When I dewinterized it there is also a line under the sink that still has some pink fluid in it that. Could that be the ice maker?
sch911
Rochester Hills, MI
Posted: 04/29/12 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
It takes 10 to 15 hours for the fridge section to get to temperature. How long has it been on?
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
ploiselle
South Shore, MA
Posted: 04/29/12 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
Put a refrigerator fan in it. They make a big difference. They also help keeping the refrigerator deiced. Here are several versions.
Battery Refrigerator Fans
I have the computer fans that attached to the fins. I have not defrosted since I turned it on in mid January.
Paul
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
Gulfstream 8378
Pleasant View
Posted: 04/29/12 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Have had it on about 5 hours and the bottom part is the same temp as when I turned it on it seems. The ice maker does not seem to be doing anything either.
garym114
Bluff Dale, Texas
Posted: 04/29/12 10:36pm Link  |  Quote  |  Print  |  Notify Moderator
It takes more than 5 hours.
Is it level?
There are specific steps for winterizing and de winterizing an ice maker.
jjwms
Nampa, ID
Posted: 04/29/12 10:45pm Link  |  Quote  |  Print  |  Notify Moderator
Put a fan in the refrigerator as others have advised. They do wonders. We normally keep our fan on a middle shelf. As far as having the refrigerator on and ice maker not working I hope you winterized it. In addition, the ice maker will only work when on shore power but I assume you already know that.
Fulltime RVer May 1997-June 2007
2013 Winnebago Vista Model 27N
MrMudstud
Lafayette, LA
Posted: 04/29/12 11:53pm Link  |  Quote  |  Print  |  Notify Moderator
If you want to max your cooling performance, do this simple trick. In the back of inside the frig on the fins, move the thermo probe from the 3rd fin to the last fin to the right or further to the right as possible. (By right, I mean when you open the frig door, the right side) Also, put it about 2.5 to 3" from the top of the fin/grille. Give it ~12 hours and it will freeze in the frig. Now, you have to play with it by moving it down slightly until the temp is where you want it.
"No One Cares What You Know, Until They Know That You Care!"......."God Bless America"
2003 Pace Arrow 34W, F-53 V-10 22,000#, Avg 8.2 MPG
ScanGauge II, Voltage Booster, Progressive Industries EMS
Water Softener, Safe-T-Plus, Rear Trac Bar, 4 Koni FSD's
ryanallie1
Magalia, Calif
Posted: 04/30/12 05:58am Link  |  Quote  |  Print  |  Notify Moderator
Hi All.
I think what you have been told is right on. These RV Fridges takes usually overnight to get up to the correct Temp. While your ad it, do yourself tewo favors.
One is to add some kind of a Fan. second, add a Thermomitor inside the fridge. That way you'll alwasy know if your food is cold enough.
A lot of us RV's have bought and put in Wireless Remote Sensors, used with In-Doo/Out-Door Thermomitors. They come as a set, so you don't have to open the Fridge Door, as every time you open the Frige Door, you let in Warn Air.
And as said, you can control the Fridges Temp, by Sliding that Bar on the Fins, either up or down as need to get the correct Temps.
If the Freezer Top is working then the bottom should be working also, as its all one unit. Maybe someone put the bar way to low and that is keeping it form getting vold enough, plus you jsut have not given it enought time to cool properly. Good Luck. Happy Travels. Dan & Jill
1998-33.5 Rexhall, Rexair SL. 460 EFI. F-53. 7.3 MPG. TST TPMS. HWH Levelers. 5.5G Gen. Convection/Microwave Water Purifier/Water Softner. 2 A/C's. Alarm Systems. Honda EU2000i's W/Kit. Steer-Safe. CR-V W/SMI System. FMCA #F414397 Nam-Vet, 66-67-68&70-71
amandasgramma
Oregon
Posted: 04/30/12 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Do you have it on propane or electricity?? Electricity takes longer to cool the fridge....ALL the advice you've received is good.
CampingJumble
San Diego
Posted: 04/30/12 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Paul
I hear those are really reliable. Thanks for the reminder.
