wolfe10
ploiselle wrote: Put a refrigerator fan in it. They make a big difference. They also help keeping the refrigerator deiced. Here are several versions.
I have not defrosted since I turned it on in mid January.
Paul
Paul,
Indeed the fans in the refrigerator will keep frost/ice down on the fins in the refrigerator section.
BUT, how thick is the ice in your freezer. That is really what determines when you need to defrost. As, I am sure you are aware, ice is a GREAT insulator. The more ice that builds up in the freezer, the higher the temperatures in the freezer, as more "coolant" reaches the refrigerator coils where the ON/OFF thermostat is located.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
chili's trip
Full time
Shipper wrote: ploiselle wrote: I have the computer fans that attached to the fins. I have not defrosted since I turned it on in mid January.Paul
If you don't wire these fans to your interior light switch, where else can you get 12V? How do you go outside the refer with the wire to connect to voltage not inside the unit? Thanks for any replies!
You can buy a reefer fan at Walmart for $16 in the RV dept. Runs 30 days on 4 D cells. Good luck!
Jack H
2005 Fleetwood Bounder 32W 8.1.
2009 Honda Fit Sport
ploiselle
South Shore, MA
chili's trip wrote: Shipper wrote: ploiselle wrote: I have the computer fans that attached to the fins. I have not defrosted since I turned it on in mid January.Paul
Jack H I did not have good luck with the battery operated ones. I wired our computer fans to run off the switch at the top of the refrigerator that for some reason keeps the light on when the door is closed. I disconnected the light from that switch and wired in the fan. The light still works off of the door switch. I have a Dometic.
Paul
41' MountainAire (MADP) -Spartan- Cummins 350 ISC
2012 Jeep Grand Cherokee Overland
2004 Jeep Grand Cherokee Limited
Brake Buddy - CoachNet
Gulfstream 8378
Pleasant View
Thanks all......We just didn't leave it on long enough and didn't have enough power going to it to get it cold.... Thanks from the newby rvers
Grey Mountain
On the rez somewhere in Indian Country
Great news! Happy RVing.
GM
Discovery 39S Tin Teepee
Honda CR-V Toad
Jeep Cherokee Toad
Enrolled member of the Comanche Tribe
English Bride
Bichon Frise bear killers:
Lord Shonefeld von Reginald-Friese IV.
Lady Annabelle von Lichenstein-Friese III.
GTN_and_Catz
Houston
From the "FWIW" Department...
I bought one of these fan kits in March after reading about them on the forum since the standard heat & humidty of a Texas spring had already helped ice up the fins on our fridge. After a few days, the fins were ice-free and everything was kept at a constant temperature. Now that summer's really kicked in, I don't see any change in performance so it's definitely the way to go.
This particular unit allows you to tap into the light for a constant 12VDC. And, if you don't want to leave it running all the time, there's a mini toggle switch on the front that will turn it off.
I'm sure you can find others - like the computer whisper fans - that will work also but this was a snap to install since it snapped (get it?) right onto the cooling fins.
Gene
2003 36' Rexhall RexAir
2009 Jeep Wrangler Sahara
Blue Ox Aventa II
2 Ragdolls
1 Tabby
Bird Freak
Calhoun, Ga.
Jack H
Thats what we use and it works great.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs-28years
We love 56 T-Birds
dennis and terry
wisconsin
if you have an interior fridge light there will be 12VDC present at all times in the light unit. get a tester and see which wire stays hot when you manually trip the door closed latch.
dennis and terry
2000 damon intruder 349 (The Boo-mobile)
cats Hunter and Jazz
dog Abigail (newly adopted from humane society)
1995 Saturn wagon toad
beech350guy
USA! USA! USA!
Post deleted
edited 02/24/13 10:12pm by beech350guy *
2007 Dodge DRW, 6sp, 2wd, QC, Firestone Ride Rite, anda pullrite Super 5th hitch.
2011 Recreation By Design, Custom designed 48' 5th wheel. 4 slides, with a lot of goodies.
Dog Trainer
Richmond Mi.
Last Summer I had a similar problem. The difference was My problem happened after having the refer running for 4 months. In that case I knew it was a problem not just the start up.After much reading and figuring I thought it was a board in the refer cooling portion. I found a Telephone number for the Dianasoar board company. The man that I talked with was very knowledgeable. Before he suggested my buying a board he helped me trouble shoot. I followed his instructions and bypassed the board I then found my lower unit was cooling. I then bought the board and fixed the problem. So after at least 24 hrs if it is not working do a search on Dinasoar boards.
93 Airstream 35' Dp
5.9 230 uprated to 300 HP
Allison MD 3060
Dutchess and Shadow Golden's Daktari Cavalier King Charles (fur Bearing Children)
