I wouldn't!. Friends and business NEVER mix well. Not saying he's selling you a "lemon" or even if friend knows it's a "lemon", but someone's gonna get hurt in end. Just my $0.02
I'd do it in a heartbeat. A 3/4-ton ext'd cab short bed versus a dually crew cab long bed, I'll take the dually long bed any day. Plus, you're getting a truck with 60K less miles on it. That's an easy decision.
Just sold my '97 F-350 CC, LB, SRW as we also have a '99 F-350 CC, LB, DRW. Since we got the dually we did not want to use the '97 to tow our 35' 5th wheel. The difference in the stability/ride is amazing.
If the dually is home and I need to run errands, not a problem, I even take it thru the bank drive-thru. Not a big deal, if the mirrors fit, the hips will fit.
Deep wedgewood blue '99 7.3L PSD F-350 Super Duty crew cab long bed dually or wedgewood blue '97 F-350 7.3L PSD crew cab longbed SRW, Member: Sunlineclub.com Rescue a retired Greyhound, greyt calm low maintenance traveling companions
For me, it would depend on the difference it will cost you, and if you feel your current truck is undersized. You wouldn't be gaining any power (unless yours is a 3.73 and his is a 4.10). How much does your RV weigh?
The 60,000 miles less on the odometer would be tempting though.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning MBRP 4" Turbo back Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
NiteMixr wrote: I wouldn't!. Friends and business NEVER mix well. Not saying he's selling you a "lemon" or even if friend knows it's a "lemon", but someone's gonna get hurt in end. Just my $0.02
That would be my only concern.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
coolbreeze01 wrote: Buy it, but don't be in a huge rush to sell the 250. When you decide which truck you prefer, then sell the other.
X2 Best advice I've seen yet.
I agree! But I'd bet you will end up selling the 250. The dually is more stable, although some will argue, but make the decision yourself comparing apples to apples. Good luck. Big butt trucks are nice!
If the difference in dollars is less than $5K. Do it in a heartbeat.
Above $5K if your happy with what you have stay put.
My comments assumes your current combo is well matched.
The dually vs. your F 250 SRW will be day vs. night in towing performance.
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
One more thing if I may. If your 99 is an early version, the 2000 will have more power. There are several differences between the early and late 99 thru the end of the run in early 03 for the 7.3. Front brake parts and hubs for one, as well as the turbo and the associated parts for the turbo. I can speak from experience about the early model front hubs and rotors, they are much more expensive. If you buy the dually and plan on keeping it for a while, mods are cheaper and more available.
