RV.Net Open Roads Forum: Class A Motorhomes: Portable Air Compressors
 > Portable Air Compressors
wilanddij
CA Desert
Posted: 04/30/12 09:16am Link  |  Print  |  Notify Moderator
From ur sig picture, it looks like u have a gasser or FRED. What chassis ru on? Get it weighed and inflate according to tire mfg's specs. IMHO, 110psi on a chassis w/o air ride will shake ur teeth out.
Will & Di
2004 Southwind 32VS
Workhorse/8.1
Jeep Wrangler/Blue Ox
"We have met the enemy, and he is us" Pogo
Devocamper
West Haven CT
Posted: 04/30/12 09:18am Link  |  Print  |  Notify Moderator
you could look into a power tank set up cost a bit more but always ready and works well. It is a co2 tank with hose and reg, a few sizes are out there, I made my own with a soft drink machine tank and reg. easier than the comps no need for power.good luck
powertank.com
08 NU-WA Hitchhiker Discover America 339 RSB
07 Chevy 3500HD LT1 EXT Cab LB DRW D/A
topflite51
In The Desert of Nevada
Posted: 04/30/12 09:19am Link  |  Print  |  Notify Moderator
Bought one from HF over 4 years ago (3ga), still going strong. I changed out the 1/4" hose for a 3/8" hose. It was cheap.
David
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to golf or fish
Simply Despicable
Any errors are a result of CRS.
Ed9824v
Agua Dulce, Calif. 70 mi S.E. of Los Angeles
Posted: 04/30/12 10:54am Link  |  Print  |  Notify Moderator
powertank.com
that what I have done for the last 4 years for the air bags in my street rod last more then a couple of years not so if filling tires regularly but most all welding supply shops will exchange for a new one I make sure I keep my aluminum one it is light.
Ed So.Calif
1950 Ford F1 street rod
1968 Baha Bug with 2.2 ecotec motor 170 hp, kingcoil
2000 National Sea Breeze 5th wheel trailer
1998.5 Dodge 2500 4x4 Cummins,4.10 gears,turbo,trans,injectors,oil cooler,lockers,edge EZ, 35" BFG's, air dog lift pump etc.
Aridon
SE Florida
Posted: 04/30/12 11:55am Link  |  Print  |  Notify Moderator
150 psi from sears.
Don't leave home without it.
2008 Newmar 4330 (Modified)
