RV.Net Open Roads Forum: Class C Motorhomes: Chassis Battery Recommendation
 > Chassis Battery Recommendation
Sea Dog
Ontario Can.
Posted: 05/01/12 06:51pm Link  |  Print  |  Notify Moderator
The starting battery in my /93 classC
was installed 08/06/99.
I leave the battery in all winter,
Last driven 1st week Oct last year.
I do not disconnect cables or use charger.
The other day, the unit cranked over instantly
as it has done for the past twelve seasons.
I have no idea why this battery,(Interstate)
has lasted so long.
Maybe it has a pink bunny inside!
Life is short,Death is long,
Take a vacation.
NewsW
US
Posted: 05/01/12 07:27pm Link  |  Print  |  Notify Moderator
Not unusual to have it last long in your application.
- low heat --- biggest killer
- few cold starts (another killer as repeated cold starts drain battery).
- good luck.
Kit Carson
Northwest Louisiana
Posted: 05/02/12 02:58pm Link  |  Print  |  Notify Moderator
I keep a battery tender trickle charger/maintainer hooked up to my chassis battery when it is in storage at home. Keeps the battery fully charged.
KIT CARSON
GOOD SAM LIFE MEMBER
USAF VETERAN
ARS: KE5VLE
NORTHWEST LOUISIANA
Coach-man
Posted: 05/02/12 02:19pm Link  |  Print  |  Notify Moderator
If you need to replace the chassis battery, consider buying a Optima battery. *They are AGM batteries and you never have to add water and they last a long time! My 2003 Wrangler I installed an optima and when I traded it for a 2009 Wrangler I was tempted to keep the optima! I am not sold on the optima's for house batteries but for you chassis battery hands down optima!! Yes they are a little more expensive too purchase than a regular lead acid battery but if you figure the cost over the life of the battery the optima's are much less expensive!
mkp
Edmonton, Alberta
Posted: 05/02/12 08:00pm Link  |  Print  |  Notify Moderator
I second the choice for a Optima AGM battery starting battery. I accidently let mine discharge totally and sit frozen at below -20C for a month this past winter. Took it out put it on a trickle charger and it was good to go for some hard starts the rest of the winter. Obviously this is not recommended and I'm sure I shortened the life but impressive none the less, a non-AGM battery may have been toast. I run two Lifeline AGM deep cycle batteries in the coach and their performance is great too (just be sure to have a proper AGM type inverter/charger).
mikeleblanc413
Sour Lake, Texas
Posted: 05/03/12 05:55am Link  |  Print  |  Notify Moderator
smkettner wrote:
All batteries last longer if kept fully charged.
Consider adding a Trik-L-Start combiner and low charge on the chassis battery will be a thing of the past.
Otherwise for superior CCA consider the Sears Platinum.
http://www.lslproducts.com/TLSPage.html
From the information provided, the Trik-L-Start is a real problem solver! I've looked at the picture of the Trik-L-Start in the link provided. Where do you place the Trik-L-Start monitor panel so you can see the colored indicators? There doesn't appear to be enough wire to place at the battery and run to the house batteries. And if you place the monitor panel midway, where do you put it so you can visually inspect? THANKS!
Mike LeBlanc, "The Digital Guy"
Professional Photographer, Retired Art Educator
Sour Lake, Texas
"Digital Guy"
Facebook
Flicker
Kamphiker
South Florida (this 'aint paradise anymore)
Posted: 05/03/12 10:52am Link  |  Print  |  Notify Moderator
Take a look at this From Winnebago
Look at the "P-Series" install. your electrical box I think is in the front compartment (exterior) on the passenger side behind a panel held in place by 2 thumb screws (at least that's where it is on my '06). This is where your relays are located.
It's a tight fit and once all buttoned up you won't be able to see the LED's to monitor which state the Trik-L-Start is in.
2006 Winnebago Outlook WF324V
2009 Honda CR-V 2wd TOAD ......Campgrounds in the Smoky Mountains NP
Last Camping trip ->2011 SUMMER SMOKY MOUNTAINS NATIONAL PARK
smkettner
Posted: 05/03/12 11:01am Link  |  Print  |  Notify Moderator
I don't have a MH but I think the instructions suggest you put it across the boost relay that temporarily connects the house and chassis battery to give a start boost. Otherwise if all batteries are in one compartment you would just connect across the positive terminals. I think you could also connect across the battery isolator if so equipped.
Once you have it connected and verified working I don't think you will need to spend any time monitoring it.
675 watts solar
oldtrucker63
Harlan Kentucky
Posted: 05/03/12 06:26pm Link  |  Print  |  Notify Moderator
For a start battery, Interstate.....Hands down.....
Without Trucks,....America Stop's
mikeleblanc413
Sour Lake, Texas
Posted: 05/03/12 06:56pm Link  |  Print  |  Notify Moderator
Bought a new Interstate battery on Tuesday...went to an Interstate All Battery store in Beaumont...when I asked the salesperson about the age of the batteries they sold he told me none of them were over a month old and he would show me how to tell the age...I'm pleased...now I'll address the drain problem with Trickl Charge (not spelled correctly)...THANKS to everyone who participated...about the only unfinished item is the TireMan valve stems..they're in...and I'm searching for the right shop to do the job...it's hard these days to find people who are as interested in doing the work as you are in having it done. We had that problem when we wanted a fence...I built the privacy fence and we had that problem when we wanted a paver patio...I built the patio. I will not put on the TireMan valve stems. Have a GREAT evening!
* This post was edited 05/03/12 09:31pm by mikeleblanc413 *
