batesrt
ohio
We have a 2006 towable, bought it used, has the white fiberglass sides.....
Trying to figure out what everyone uses to wash it? Regular soap/mitt seems fine for the worst of the surface dirt, but doesn't see to remove bird******or tree berry stains etc very well, or dirt that's really set in.
Would something more harsh like an Acetone be too corrosive on there, or any other ideas?
Thanks much
Grammie
North Carolina
Try Awesome from the dollar store. Works really well on black streaks. Might want to dilute it with water and not use full strength. Good stuff and only a dollar.
Dream Catcher
Rolling Condo
South Carolina
To wash and wax do a search for Red Max Pro here on the forums.
'90 GMC R2500 7.4L w/ Gear Vendor OD
'90 Avion 34V
Cummins Onan P4300ie
Pro Pride 3P
Prodigy
JKQ
I use a couple different items. Usually a RV or car wash soap, sometime mixed with a little dish detergent to cut the grime (if necessary). Also while washing I spray Simple Green on the area to enhance the cleaning & that usually helps alot. I get the bugs off the front by wetting a dryer sheet & rubbing the area a little at a time untill there gone, be sure not to let the residue from the dryer sheet dry on the front cap as that creates a whole new problem. For black streaks I use a product made to get to get them off available at camping world or walmart
2013 CruiserRv Enterra 314 RES TT, 36ft, 3 slides
2013 Ford F250 Crew Cab Power Stroke Diesel 4x4
Reese WD hitch with dual friction control bars
Dometic 3000 KW portable genset
concord32
Indianapolis
For the money I used to take my TT to Iowa80 truck wash. They will get it all off. The soap the use takes everything but the paint. Wax included. They will hot wax it on the way out but will give you a place to start. All for less than $50. My company gets there trucks washed there every week and they look great. Thats how I found them. If you have aluminum wheels have them do the alumabright on them they to will shine.
2011 Coachmen Concord 32' Triton V-10 1-slide.
eric james
Sioux Falls, SD
Grammie wrote: Try Awesome from the dollar store. Works really well on black streaks. Might want to dilute it with water and not use full strength. Good stuff and only a dollar.
x2 Awesome is awesome.
2009 Keystone Passport UL 290BH
2003 Ford Expedition EB 5.4L/3.73
batesrt
ohio
eric james wrote: Grammie wrote: Try Awesome from the dollar store. Works really well on black streaks. Might want to dilute it with water and not use full strength. Good stuff and only a dollar.
Nice I just tried it out for a small section and it works great (awesome). I assume you just rinse it off with water, or soap/water?
