Maxtorr
High Point, NC
I have a 2001 Fleetwood Southwind 35R. I want to replace the factory installed reclining chair with a new Laze Boy recliner. My question is how best to remove the original chair. I thought it was like the Captain’s chair and by removing the very large center nut you could just lift it out but no go. Any help appreciated.
Thanks
High Point, NC
Maxtorr
High Point, NC
Tryed to insert photo but I must of done something wrong??
robsouth
Near Atlanta, GA
PM me the photo and I will post it for you.
"Sometimes I just sit and think. Sometimes I just sit." "Great minds like a think."
1995brave
San Antonio, TX
You probably have four bolts on the floor hidden by the carpet(can't see picture, just guessing). Peal back the carpet, remove the four bolts, and the chair should lift right out.
robsouth
Near Atlanta, GA
Photo of chair
tomousecap
Wherever the Bounder is
Looks like the standard recliner that Fleetwood uses to me. They are just mounted on a floor ring that is secured by a clamp held down with a threaded knob. Easy to remove..... You can remove the ring from the recliner and mount it on a replacement chair if you like. Pretty easy to adapt to it.
Bob
2007 Fleetwood Bounder - Full Paint 35E
Workhorse 6 Speed 496 Cubic Inch V8 - W22
Ford fans - RPM is a poor substitute for Cubic Inches!
2013 Chev Volt - Towing on a Master Tow Dolly
Gracie = Adopted longhair Amazon Chihuahua
Scavenger Power Exh. Installed.
Clay L
Sioux Falls, South Dakota
tomousecap wrote: Looks like the standard recliner that Fleetwood uses to me. They are just mounted on a floor ring that is secured by a clamp held down with a threaded knob. Easy to remove..... You can remove the ring from the recliner and mount it on a replacement chair if you like. Pretty easy to adapt to it.
I wanted my new rocking recliner to swivel so I did as you suggest and made a 3/4 inch plywood adapter that allowed the ring and swivel mechanism to attach to the recliner. Works great.
Clay (WA5NMR), Lee (Wife), Katie (cat).
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
CampingJumble
San Diego
Thanks
Your image isnt showing good sir.
garym114
Bluff Dale, Texas
If you have to stop fast or get into an accident you and the passenger will be stopped by your seat belt. What is going to stop the new recliner?
mtrumpet
Hamburg, NY
1995brave wrote: You probably have four bolts on the floor hidden by the carpet(can't see picture, just guessing). Peal back the carpet, remove the four bolts, and the chair should lift right out.
OR POSSIBLY, as with mine, the bolts could go through the floor down into the cieling of one of my cargo bays. There's a nut on each bolt there underneath. Just remove the nuts (and washers), pull the bolts up through the floor and you'll be free to move the chair.
That chair looks identical to mine, although mine is black leather. They're usually made by Flexsteel.
Mark & Cherie (& Chloe)
2002 Newmar Dutch Star DP 3872, Cummins 350 ISC, Spartan Chassis
