fla-gypsy
North Florida
There is no way I would pull a 9300 GVWR trailer with a 5.3L plus it will have 1100 lbs of tongue weight when loaded. Not enough motor or payload for the 1500 IMO.
easycamper
Ontario's West Coast
Another point in favour of the White Hawk 27DSRL is the more aerodyamic front profile. Makes more difference than a lot of people think.
2001 Ram 1500 5.9L Lariat QC SB 3.55
2005 Vanguard Kodiak 22+2SL 5th-Wheel
Ron Gratz
full time RVer
Mark42 wrote: Ron
My truck sticker states 7000lbs
Just the 2 of us, I'm 220lbs wife is 140ish??
probably 200lbs of "stuff" in the bed of the truck. The placard to which I was referring is shown on this web page. (Your label might have a different format.)
The specific information is contained in the statement which reads:
"The combined weight of occupants and cargo should never exceed XXX kg or YYYY lbs."
The YYYY value is the number we need.
Ron
Mark42
Garner, Iowa
Ron
2007 GMC 1500 ext.4x4, 5.3L, 3.73axle
2003 Jayco 256D Travel Trailer
Reese Dual Cam
mlts22
Austin, Texas
If you start getting past 7000-8000 pounds dry, which realistically means over five digits when fully loaded, I'd go for a 3/4 ton, be it a Chevy 2500, a Ford F-250, or a Dodge 2500. There is a big difference between a half ton and a 3/4 ton when you hit the grades, the higher altitudes, or both.
I made this mistake myself... if I don't go for a motorhome, I'm going to be getting a 3/4 ton or 1 ton which is designed to handle heavier loads (and doesn't have to dance around CAFE numbers.)
Ron Gratz
full time RVer
Mark42 wrote: ---Is this reasonably doable? If "doable" means staying within GMC's weight ratings, IMO it might be doable.
For your truck, how much trailer you can tow most likely will be limited by payload considerations.
To provide a meaningful answer to your question, we need three pieces of information:
1) What is the maximum allowable "combined weight of occupants and cargo" stated on the driver's door placard?
2) What is your best estimate of the actual weight of occupants and cargo, including 80# for a weight distribution hitch, when loaded for camping?
3) What is your best estimate of weight of cargo, including any fresh water or waste water in the tanks when underway, to be carried by the trailer?
Given the above information we will be better prepared to provide advice.
Ron
smkettner
I recommend you keep the trailer GVWR inside the truck tow rating.
675 watts solar
Mark42
Garner, Iowa
I checked the sticker on the drivers door, it stated 7000lbs
dodge guy
Bartlett IL
buzzard616 wrote: Ya gotta use 'official' numbers. Your truck (or the one you're looking at) has CVWR (total weight of truck, trailer, beer, dog, kids, etc).
That number cannot be exceeded; especially in a country with so many lawyers.
Do the math. Pick the right combo. Enjoy life on the road.
I saw a TT pushing thirty feet at an RV show last month and it was proudly labeled " half ton towable ". A check on the little silver sticker on the left front corner showed a gross weight of 9350lb.
Not my half ton!
Stu
What was the dry weight? some trailers have a high CCC. so it may very well have been 1/2 ton towable.....a properly equipped 1/2 ton. for instance my TT has a GVWR of 11,200lbs with a CCC of 4100lbs, (7100lbs dry).
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
buzzard616
Medicine Hat, Ab, Canada
Not my half ton!
Stu
Stu & Jackie Metcalfe
2000 Salem 27FKSS
2008 Sierra 2500 HD gasser
