RV.Net Open Roads Forum: Should I go 3.73 or 4.10 with my Chevy 6.0?
 > Should I go 3.73 or 4.10 with my Chevy 6.0?
Page of 6
egarant
Mission Viejo CA
Posted: 04/30/12 02:01pm Link  |  Print  |  Notify Moderator
Butch50 wrote:
sirdrakejr wrote:
Is it a SRW or a DRW truck? That TC is way too much for a SRW I believe. I would weigh the truck and then see what you have.
Frank
Frank,
One thing you have to remember is these new SRW Chevy and Ford trucks can have a GVWR of over 11,000# not like your Dodge with a 9,900 GVWR the same as my 2006 3500 Dodge had with a diesel. My 6.2 truck has a GVWR of 11,200#. This is 1300# more than my Dodge and my 6.2 engine is sure lighter than my Cummins was.
The heaviest NL is the 10-2 CDSE and the dry weight on it is 2970 and this is with almost every option the NL offeres but it is standard on the CD unit. About the only additional is the generator. NL weighs every unit when it leave their lot and puts this weight in the cupboard. I use to own a 10-2 CD and know that I didn't overload my 2002 Chevy EC 4X4 Dmax/Allison and it had a 11,400# GVWR. This unit is less than 300# more than your unit but it already has the AC on it with side, rear awnings, electric jacks, dual pane windows,TV and DVD, microwave oven.
He may have to go with 19.5 as you did on yours.
This is IMO
Hi Butch,
I spoke with the sales rep. up in Portland OR, my closest dealer. He ditto's what you said about the weight being inclusive with the options. I figured with an additional generator, solar panel, full water and propane tanks and 500lbs of gear (the gear migh be high), I will be at 4,000 lbs. I think cargo carry capacity of the truck I am getting is 4,192 lbs.
smkettner
Posted: 04/30/12 02:20pm Link  |  Print  |  Notify Moderator
Mileage will not drop when unloaded enough to notice. Could even go up a bit when the camper is on due to better power to load match.... 90% of the time.
The only reason to only go 4.10 is because 4.56 is not available.
675 watts solar
Turbo Diesel Dude
Green Mountain, NC
Posted: 04/30/12 03:39pm Link  |  Print  |  Notify Moderator
Once upon a time, I had a 2011 Chev 2500HD ExtCab 4X4 6.0 and 4.1 gears. Taking it easy, I got max of 8MPG towing my 9K TT with 1000 lbs tongue weight. Went all the way to 12 empty once again taking it easy. Had enough power, but coughed going by gas stations. Went back to a diesel, same year, Crew Cab 4X4 6.6 Duramax. I get right at 11 towing same TT and close to 17 empty. Just my experience, but you do what you want as it's your money. JMHO
charles weidman
big whitey
raleigh,nc
Posted: 04/30/12 04:52pm Link  |  Print  |  Notify Moderator
i have the same truck only in 2500 dress.unless you enjoy a transmission that will downshift on the tiniest grade DO NOT repeat DO NOT even consider anything less than the 4.10.my 2011 6.0 with the 3.73 rears gets between 9 and 10 mpg with the TC (8.5 North*)which is much lighter than a NL.if $$$ and reliability were not a consideration i would have went the diesel route.
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/30/12 05:35pm Link  |  Print  |  Notify Moderator
4.10
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
MERC225
Wisconsin
Posted: 04/30/12 06:02pm Link  |  Print  |  Notify Moderator
I would go with the 4.10 for sure! I wish I would have when I bought my 2005 Ram 2500, it was a big mistake not getting the 4.10. You will get much better performance out of the V-8 if you can keep the RPM's up while working it, that is how V-8's are meant to work, at higher RPM's.
If and when you do get the truck, post the performance with the camper on it, especially if you decide to go with the 4.10. I am interested in the exact same setup.
2005 Dodge Ram 2500 4x4 Quad cab long box, 5.7 Hemi, Rancho RS9000XL shocks, Rancho MyRide system, Supersprings, Roadmaster rear sway bar.
2008 S&S 9.5 FBSC camper
eye8Ubutler
Maritime Provinces
Posted: 04/30/12 06:21pm Link  |  Print  |  Notify Moderator
Our TV has 4.10 with a 4 speed.
It happily goes over considerably high inclines in 'cruise' and 'tow haul mode' WITHOUT having to seek 3rd gear.
Chevrolet Silverado 1500 LTZ 2007 (new shape)
4x4 Crew Cab VORTEC MAX (L76) 6.0L V8 4L70E 4.10 axle
factory NHT Max Trailering Package.
2010 Coachmen Freedom Express 280 RLS
"...a Waldorf Salad?, sorry we are fresh out of Waldorfs!".......BASIL FAWLTY.
chrisjpr
Owosso
Posted: 04/30/12 06:32pm Link  |  Print  |  Notify Moderator
4.10 for sure. Especially if you ever decide to go with a slightly larger tire(higher load capacity).
recycler
michigan
Posted: 04/30/12 07:04pm Link  |  Print  |  Notify Moderator
go with the 4:10 ratio..the milage shouldn't be much different 1 or 2 i'm guessing... the little it sounds you will have it unloaded it won't matter much
1968 franklin 11fk
back to my 93 cummins
cewillis
Tucson, az, usa
Posted: 04/30/12 07:29pm Link  |  Print  |  Notify Moderator
So is the consensus that a 6.0 gas engine and 4.1 gears has enough torque for the planned load and boat?
(I understand the cost and weight penalties of a diesel, but axle gearing wouldn't be my first worry in that situation)
Cal
Page of 6
