RV.Net Open Roads Forum: Truck Campers: dually bracket question...again
 > dually bracket question...again
campn4walleye
Central WI
Posted: 04/30/12 11:53am Link  |  Print  |  Notify Moderator
Here's another question concerning dually swingout brackets.
Previously, we asked the question regarding spacing, but as we look at ours, we have noticed that our swingout brackets appear to be Atwood swingouts on our Happijac jacks. They were installed by the dealer and to make them fit, they had to drill out a hole a bit. DH swears that the jack appears to be bowed.
Can a different dually swingout bracket be matched on a different type of jack? Does this need to be addressed by the dealer? They never told us they couldn't match them. Would it be helpful to see a picture?
Thank you.
2011 Adventurer 910FBS,Torklift tie downs,Fastguns & Wobbl-stopprs
2012 Dodge 3500 DRW 6.7L CTD, 4x4, LB,CC,6 speed auto,3.73 axle, General 17" on/off road
2008 Lund 1825 Explorer Sport,115 Merc,9.9 kicker,Torklift Super Hitch,42" Supertruss
USAF ret E-9&E-7
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/30/12 05:39pm Link  |  Print  |  Notify Moderator
As long as the bracket holds the jack to the camper effectively and swings in and out, it doesn't matter what the brand name is on it.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
kerry4951
East Central Pennsylvania
Posted: 04/30/12 06:37pm Link  |  Print  |  Notify Moderator
If you have Happijac jacks then they should of used Happijac dually swingout brackets. Thats not saying that you couldn't make another brand work, because apparently they did. Is it the right and correct way......I would say no.
2009 Chevy Silverado 3500 dually D/A, Supersprings, Stable Loads, Bilstein Shocks, Hellwig Sway Bar, Front Timbrens.
2010 Arctic Fox 1140 DB, 220 watts solar, custom 4 in 1 "U" shaped dinette/couch, 59 interior and exterior mods to date and still adding
Super_Dave
Sacramento, CA
Posted: 04/30/12 06:42pm Link  |  Print  |  Notify Moderator
What I read as potentially the bad news, I thought the answer to your previous post was that the Atwoods had the biggest swing for your too tight jack problem. If you already have that, you appear to need bushings for the jacks to push them farther out.
Truck: 2006 Dodge 3500 Dually
Camper: 2007 Eagle Cap 850
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
NRALIFR
Truck Camping Out West
Posted: 04/30/12 07:03pm Link  |  Print  |  Notify Moderator
I don't see a problem with using Atwood dually swingouts with HJ jacks, even if they had to drill out a hole a bit. That in itself isn't going to cause the jacks to bow. It's just a hinge, after all.
There are alignment considerations though, and there is enough play in all the mounting holes that you could end up with the jacks splayed out (or in) at the bottom if you weren't paying attention when you tightened everything up. It may be that all that's needed is to loosen all the bolts up while the camper is sitting int he bed of the truck, straighten the jacks, and then tighten it all back up again.
A picture would be great if you could post one.
2001 Lance 1121 on a 2010 F450
Flyfisher86
Catskill Mtns.
Posted: 05/01/12 05:55am Link  |  Print  |  Notify Moderator
There is no problem with using the atwood swingout brackets. But that being said using the atwood brackets actually does not give you the same amount of clearance because of the design of the Happi-Jacs. The atwoods have a mounting bracket welded onto the tube extending the jack out where as the Happi-Jac tube bolts directly to the bracket there by moving the jack in the width of the tube on both sides so you loose clearance because of that. If you do an image search on the brackets you will see what I mean. Personally I prefer the way the Happi-Jac brackets work over the other two manufacturers and I have used all three.
2009 Dodge 3500QC DRW Flatbed 6.7CTD 6Spd Auto
2009 Northern Lite 10-2CD Special Edition 200w of solar and one spoiled camper dog Splash
mkirsch
Rochester, NY
Posted: 05/01/12 11:09am Link  |  Print  |  Notify Moderator
I had to drill new holes in my Atwood swing-out brackets to fit Atwood jacks...
It was no big deal. After all, it's just a simple hinge fabricated from mild steel. There's nothing special about any of the jacks or swingout brackets. You're not going to appreciably weaken them by drilling out a hole, or drilling an extra hole. If they're rated for 2500lbs each, you might've reduced the capacity to 2499lbs...
If the jack is attached solidly, then don't worry about it.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
Super_Dave
Sacramento, CA
Posted: 05/01/12 02:23pm Link  |  Print  |  Notify Moderator
Tricia, not worry? Now that's funny! I know she is still thinking about leaning jacks and in sufficient clearance of the jacks with the truck. I think I would want to leave the truck & camper at the dealer for a couple of days to get everything ironed out once and for all. I know there has already been a lot of anxiety burned to date.
