C-Leigh Racing
Nashville NC
There should be a fitting, on the end of the metal tube that goes threw the frame rail, where you can put a wrench on & then another wrench on the rubber hose to take them apart.
Where the rubber hose connects to that metal tube, it can be a bugger bear to take apart & real easy to mess up the hex nut of the fitting using the wrong type wrench.
I would say, spray that fitting good with some PB Blaster & let it soak like over night first & then tackle it the next day.
Try to be careful as you can with the wrenches, not letting them slip on the hex nuts, cause if you do, you'll be down to a pair of vise grips trying to get it apart & then replacing that metal tube afterwards.
You might need another person, to hold the tube & hose to keep from bending them when you put pressure on the wrenches.
I've done a few of those hose replacements & the fitting where it goes threw the frame rail is the worst part of the whole change out to get apart.
Use some good quality fitting wrenches & it will make the job a bit easier.
Neil
crankshop1000
se michigan
edited 05/01/12 02:57pm by crankshop1000 *
OnaQuest
Old enough to be a
enblethen wrote: There should be a flare fitting on the steel line that comes apart there. The hose itself as shown in O'reilly's site is all one peice and is crimped together.
My problem is, that the hose fitting on the end of the hose that goes through the frame rail is not accessible from the rear (other side of the rail) I can't see or reach the metal hose to detatch it.
This is the first vehicle that I've had trouble with this condition.
I started with the left front, but will study the right side to see if I can find a way to get to the rigid line connection.
I have tubing wrenches and know how to open brake line fittings.
This particular '97 chassis has always been a little weird in matching parts. I think it's part '97 and part transitional to the '99.
edited 05/01/12 09:10am by OnaQuest *
OnaQuest
Old enough to be a
crankshop1000 wrote: It's amazing how many people ask questions about BASIC MECHANICAL SKILLS involved with working on critical systems on a motorhome that will be carrying your family.If the OP was indeed so skilled as to not need tutorials,he certainly would not be stumped with removing a flex hose fitting.The whole point here is that if you don't know a basic hydraulic fitting,you probably don't know how to safely install the new one and all that you may encounter with the project.Harsh,but needs to be said.A man needs to know his limitations.
It's amazing how many people will jump in with criticism without knowing anything about the problem or the person asking the question. I suspect that I've turned a few more wrenches, than you have, in my lifetime.
Don't judge others by your obvious lack of skills. Your BS (not Basic Skills) is not appreciated.
edited 05/01/12 09:14am by OnaQuest *
OnaQuest
Old enough to be a
C-Leigh Racing wrote: There should be a fitting, on the end of the metal tube that goes threw the frame rail, where you can put a wrench on & then another wrench on the rubber hose to take them apart.
Neil
Neil, the problem with this particular chassis, is that there is no obvious access to the other side of the frame rail to get to the junction of the solid line and the fitting on the hose. There is a frame cross member in the way that I don't remember ever being faced with before.
BTW - have you used your RMP-3 yet?
crankshop1000
se michigan
OnaQuest
Old enough to be a
crankshop1000 wrote: If you are asking how to remove a simple hydraulic line,you should not be working on your own brakes. I know how the line comes apart.What is obvious about my lack of skills other than you want to play mechanic and not everyone agrees with the idea of unskilled people working on brakes? Hows this? You can get a chisel and a hunk of flat steel,take a big hammer and whack the hose until it's apart.Now get a saw and cut pieces of the remaining lines off until you get to something that looks familiar to you.Cit off there and get a bunch of adapters and some small garden hose and a handful of clamps and get to fabricating.Load all your friends into the coach for a test ride.
Thank you crackpot.. err.. crankshop,
Just what I needed, a detailed procedure. You are too kind.
crankshop1000
se michigan
96Bounder30E
America is my home!
Onaquest.....
I know exactly what the brake line you are working on looks like....I wish I had some advice for you......I can't believe Ford would assemble something like that....
How about posting a picture here for everyone to see......maybe if they see a picture someone might have a creative solution for you?
Eric
96 Bounder 30E-F53(460)
stock Ford intake w/K&N air filter
used Thorley headers
new Banks resonator, muffler, tail pipe and 4" polished SS exhaust tip
OnaQuest
Old enough to be a
Having trouble attaching photo post
