BigLar368
Home
Well I changed out a faulty A/C unit today and no matter how careful I was I still managed to make two very small tears in the roof. The two tears are about a 1/4" long and are all the way through to the wood decking. I don't have any eternabond and it will take a couple of days to find some however I have a brand new tube of Dicor. Since the tears are so small would just the Dicor work? By the way the tears are so small I had to mark them with a sharpie so I could find them when I went back up there. Thanks in advance.
weathershak
Not sure, I need to look out the window
Dicor will work fine.
Full timing it since July 2012 My pics
BigLar368
Home
Thanks for the quick replies. I will Dicor it now and tape it later. Thanks again.
downtheroad
Pacific Northwest
Dicor will work just fine...but
I like Eternabond even better.
If it isn't going to rain in the next couple of days, I'd probably wait the couple of days it will take you to get Eternabond...
Maybe even just cover over the 1/4" tears with some duct tape until you get the Eternbond..
GMC Duramax LBZ
Komfort
Reese Dual Cam HP
Our Rig Picture...CLICK HERE
Randu
South Central Michigan
I'd use the Dicor now and then cover with the Eterabond on top for insurance. Randu
2004 GMC 2500HD 8.1 Big Block gas
2008 Mobile Suites 36TK3
john b
anywhere USA!
You can easily go over the Dicor with Eternabond when you get it just don't put the Dicor to mounded so the ebond will lay flat. JMHO Jb. Get it protected now!
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
jimmyfred
Tx
..............I'd take that trailer and temporarily store it under cover until I rece'd my new roll of eternabond ! Dicor is going to take several days too form a hardened , sealed surface . And , you can't reset your airconditioner until the dicor seals ! Eternabond seals instantly and presents a uniform , strong surface to rest the air unit upon , instantly.........NOT 5 days from now ! , jf
2003 Chevy 8.1 Dually 2Wdr.
1999 Travel Supreme , 33 RLSS
20K Reese , Prodigy etc.
gbopp
The Keystone State
Randu wrote: I'd use the Dicor now and then cover with the Eterabond on top for insurance. Randu
x2
Johnworth914
USA!
Dicor will do the job until you can get some eternabond.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
redsb3
Tucson
If you have a nearby Walmart, check the Auto Dept. I was surprised to find a roof patch kit in the RV section with ETERNABOND repair tape in it.
2005 GMC Sierra SLT CC/SB with 6.6L Duramax/Allison
2002 Automate 5W, 32 ft, 13,280 GVWR
Valley Glider Hitch
