RV.Net Open Roads Forum: Tech Issues: A water heater by pass question
 > A water heater by pass question
NanciL
Bakersville, NC, USA
Posted: 04/30/12 03:08pm Link  |  Print  |  Notify Moderator
My by pass system works perfectly, but I still cannot understand what prevents the water from entering into the tank via the hot water pipe when the system is in by pass mode, and I am hoping some one can give me an explanation.
My system is as follows: It has one valve in the incoming cold water line (call it valve 1).
Then there is a by pass line in front of that valve that goes to the out going hot water line, and in that line there is another valve, (call it valve 2).
In normal mode, Valve 1 is open and valve 2 is closed which makes perfect sense to me
In bypass mode, valve 1 is closed and valve 2 is open sending the pink stuff to the hot water line. I don't understand what prevents the pink stuff from entering the tank via the hot water line, but for some reason it doesn't, and it does go through the rest of the hot water lines
Is there some sort of a check valve in the outgoing hot water line at the tank?
If anyone can explain it I sure would appreciate it
Jack L
Jack & Nanci
othertonka
Stockton, CA
Posted: 04/30/12 03:13pm Link  |  Print  |  Notify Moderator
Bingo, you got it rght, there is a check valve at the tank outlet
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Old-Biscuit
Across the USA
Posted: 04/30/12 03:44pm Link  |  Print  |  Notify Moderator
Sounds like this is what you are describing
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
RoyB
King George, VA
Posted: 04/30/12 03:50pm Link  |  Print  |  Notify Moderator
My hot water heater bypass has the third value as shown here.
I was wondering how the two valve models were working my self haha.... Thanks for the post... Now I am smarter about it...
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Hurricaner
Hurricane Utah
Posted: 04/30/12 06:42pm Link  |  Print  |  Notify Moderator
No check valve in a three valve system.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
Old-Biscuit
Across the USA
Posted: 04/30/12 11:02pm Link  |  Print  |  Notify Moderator
Sam
My three way has a check valve on hot outlet....looks like a threaded nipple but has an internal check valve.
Snow_King
Gold Canyon, AZ
Posted: 05/01/12 07:27am Link  |  Print  |  Notify Moderator
There are also one valve plus check valve solution. The one valve is a Y valve the switches water to the inlet or to the cross over pipe.
Somewhere in a Fifth Wheel - Where it does not Snow
Hurricaner
Hurricane Utah
Posted: 05/01/12 07:35am Link  |  Print  |  Notify Moderator
Old-Biscuit wrote:
Sam
The pic you posted is a 2 valve system. The 1 and 2 valve system uses them, the three valve does not need one. I prefer the three valve as sooner or later the check valve will fail and it can be a pain to change.
Sam
larry barnhart
wenatchee. wa usa
Posted: 05/01/12 09:09am Link  |  Print  |  Notify Moderator
I thought our suburban water heater had the check valve at the entry to the heater at the (bottom)of the tank. No water in so no water out. Am I wrong??
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
NanciL
Posted: 05/01/12 03:45am Link  |  Print  |  Notify Moderator
Many thanks
I figured that is what it had to be, but never knew they did that
Jack L
