RV.Net Open Roads Forum: Fifth-Wheels: simple question tire replacement
 > simple question tire replacement
machunt
cincinnati ohio
Posted: 04/30/12 03:10pm Link  |  Print  |  Notify Moderator
I have the st23580r16 on a 2011 321 outback all i wanna do is change them out for LT tires, what are my choices
NC Hauler
Asheville NC
Posted: 04/30/12 03:18pm Link  |  Print  |  Notify Moderator
What is the GVW of the 5er? What weight range tire are on the 5er now? what are your axle ratings? If 6,000# axles....I like the Michelin XPS RIBS....if "E" rated is applicable...."IF" a G rated tire, your limited to several, but the GY G614RST tires are for 7,000# axles. There are several other LT tires that will work with 6,000# axles that will probably be mentioned, but again, would be nice to know the 5er's GVW and what load range the OEM tires are to better answer your question.
Jim & Kathy
2013 Dodge 3500DRW Longhorn 4X4/CC/LB/Aisin tranny/4:10/Cummins: 385HP/850TQ
06 HR Presidential Suite 37RLQ/ 4 slide/ dual pane windows/Winegard SK3005 Satellite/Splendide XC2100 W/D
Boxers;Buddy& Sheba II
USAF 71-75 Nam Vet
WVU fan
Snow_King
Gold Canyon, AZ
Posted: 04/30/12 03:37pm Link  |  Print  |  Notify Moderator
machunt wrote:
Present tires are load range E. axles are 5.200 lbs 3 inch, trailer weighs approx 11,000lbs just a guess. i cant go bigger because i onle hace about 3inches or so between tires
So look at LT245/75R16E's.
Somewhere in a Fifth Wheel - Where it does not Snow
Francesca Knowles
Port Hadlock, Washington
Posted: 04/30/12 04:07pm Link  |  Print  |  Notify Moderator
It's not as simple as it sounds...depending on manufacturer, an LT tire of an "equivalent" size may have a lower load rating.
For example:
This link to a Goodyear site indicates that an LT245/75R16E has only 2680 pounds of capacity, which is considerably less than the 3,420 pounds listed for the ST23580R16E's you're running now.
There's also a considerable difference in tread depth/design. Since it has to serve on drive/steer axles, the LT's tread is quite a bit deeper/more aggressive. Since trailer tires need only "follow" the tow vehicle, the tread is shallower and straighter. This design not only helps prevent the towed unit from trying to "steer" the tow vehicle, better rolling resistance performance results in fuel savings overall.
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
oldelmer
North East, MD
Posted: 04/30/12 03:22pm Link  |  Print  |  Notify Moderator
Have you gone to the scales and weighted your camper?
If you are under 12,000#, you can use LT tires instead of ST tires.
2010 Montana 3150RL
2011 Dodge RAM 3500 DRW, 4x4,6.7 CTD, Auto, 3.73, CC/LB
Line-X Spray in Lining
KSH Tool Box/Fuel Tank Combo
machunt
cincinnati ohio
Posted: 04/30/12 03:24pm Link  |  Print  |  Notify Moderator
Allworth
Orlando, FL
Posted: 04/30/12 04:28pm Link  |  Print  |  Notify Moderator
X 2 on Snow King. The 245/75s are almost an exact replacement on 16" rims. In Load Range E they are rated at about 3200# each @ 80psi (depending on brand).
Look at B.F.Goodrich Commercial TAs. Great combination of price and wear in a US made tire. Watch the "born on" dates.
On Edit: I may be reading that chart wrong, but I see 3042# at full inflation for that LT tire.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
2008 Titanium 30E35SA; EZ-Lube axles; wet bolts; spring hanger gussetts; BFG Commercial TAs
"Real Trucks Don't Have Sparkplugs"
Dennis M M
Geneva, IL; Tucson, AZ
Posted: 04/30/12 04:44pm Link  |  Print  |  Notify Moderator
Michelin XPS Ribs - 235/85R16
Here is Michelin's weight chart for RVs
Our fiver runs about 18,500 lb. loaded, (20k GVWR, 3,500 lb. pin wt.). Two 9,000 lb. axles with duals (eight tires).
We ran over 50k miles on the same size B F Goodrich LTs and have over 10k on the Michelins. I run 65 psi cold, use Pressure Pro, and had one failure in that time due to a nail in a sidewall - no on road failures (knock on wood!).
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'11 smart fortwo on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
retired in utah
Ogden, UT
Posted: 04/30/12 05:11pm Link  |  Print  |  Notify Moderator
Agree with Dennis MM. Michelin radials are expensive but worth the price. Ran them on my 5er and only changed after 5 years. Never had a problem with them. On the new 5er, immediately replaced the OEM tires with Michelin XTA radials.
2011 Ford F350 Dually
2011 Mobile Suites 36TKSB3
Reese 25K Hitch
Michelin 17.5 XTA Radials
NC Hauler
Asheville NC
Posted: 04/30/12 05:16pm Link  |  Print  |  Notify Moderator
As I stated above, believe the Michelin XPS RIBS would be a better tire for the axle weight on his 5er. Maxxis makes a good one also...But the RIBS have proven out; expensive, but WELL worth the money for the security they will afford the OP.
