RV.Net Open Roads Forum: Fifth-Wheels: simple question tire replacement
 > simple question tire replacement
Farmer David
Mattoon, ILL.
Posted: 04/30/12 05:32pm Link  |  Print  |  Notify Moderator
I had the the same size st tires on my trailer when I changed I went to 245/75 16 LT tires almost the same size I went with Firestone Transforce and am very happy with them
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
JIMNLIN
out here
Posted: 04/30/12 06:40pm Link  |  Print  |  Notify Moderator
I have 5200 lb axles on my 11200 lb 5er. I use the BFG Commercial 16" LT215/85-16 E at 2680 lbs capacity each. Ran the first set for 55k + miles and over 7 years. I'm on the 2nd set and have had zero issues.
'97 Park Avanue 28' 5er 11200 gvwr two slides
FastEagle
Taylors, SC
Posted: 04/30/12 06:54pm Link  |  Print  |  Notify Moderator
machunt wrote:
I have the st23580r16 on a 2011 321 outback all i wanna do is change them out for LT tires, what are my choices
Is your trailer a fifth wheel or trave ltrailer? Is it a Keystone product? I've looked at all the Keyston specs for 2011 and cannot find a 321.
FastEagle
Dickinson, ND
machunt
cincinnati ohio
Posted: 04/30/12 07:16pm Link  |  Print  |  Notify Moderator
http://www.flinthillsrv.com/rv/keystone/........hwheel/11/Keystone_Outback_Sydney_321FRL
here is my fifth wheel
iam not sure if i can go with a 85 because my wheels are to close together
FastEagle
Taylors, SC
Posted: 04/30/12 10:44pm Link  |  Print  |  Notify Moderator
Are you having problems with your tires? Keyston does not have a habit of putting so much reserve load capacity in their tires. You should have 1840# reserve load capacity per axel with those tires aired to the sidewall pressures. No reason they should give you any problem.
321 specs
FastEagle
machunt
cincinnati ohio
Posted: 05/01/12 05:59am Link  |  Print  |  Notify Moderator
Fast Eagle i understand the fact i have plenty of excess weight capacity but i believe they are cheap tires. and i do put alot of miles on my 5ver a year in the neighborhood of 7000 miles -10,000
FastEagle
Taylors, SC
Posted: 05/01/12 03:26pm Link  |  Print  |  Notify Moderator
Sometimes junk is in the eye of the beholder. I'm using that size tire by choice (3520#) and have not had a filure since 2006 and I'm on a second complete set. My axles are 6000#.
FastEagle
* This post was edited 05/02/12 01:58pm by FastEagle *
