RV.Net Open Roads Forum: Tech Issues: Upgrading my Magnatek 7355
 > Upgrading my Magnatek 7355
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/30/12 05:14pm Link  |  Print  |  Notify Moderator
If your 55 is in good shape we could use one at a rural clinica de salud, which is a first-aid station. I brought down a pair of US Battery GC-2's but the 20 amp "Smart Charger" isn't robust enough to keep these batteries charged between blackouts in the hurricane season. Many times, 5 hours without power than four with, then another 8 without. A generator won't work because of lack of funds to build a separate building for it. Hurricanes saturate everything unless housed in a really well designed structure. A good 55 amp charger PLUS the 20 amp smart charger will work. You probably saw my earlier question asking about inverters. A friend is coming down with hopefully a 300 watt sine wave unit that can run CFLS charge a defibrillator, and run the SCT FM emergency transceptor.
mexbungalows@gmail.com
or PM me if interested
azbohunter
arizona
Posted: 04/30/12 05:43pm Link  |  Print  |  Notify Moderator
If I change it out I will keep you in mind! Kind of sounds like I may not have the issue I thought I had though!
2006 Dodge Quad Cab Cummins 5.9 Automatic 4x4
2002 28RKD Lakota fifth wheel
Pullrite Hitch
2006 Polaris Ranger
16'Lund w/50HP Merc tiller
A great wife who loves to travel and fish
I love to archery hunt/she joins me and cooks!
smkettner
Posted: 04/30/12 06:35pm Link  |  Print  |  Notify Moderator
Not sure Optima has a group 27. Small are about 55 amp hours and large D31T is 75 amp hours. If they are end of life I think it seems a bit early and probably helped along with too high of float voltage. Some have had success in reviving Optima with a better charger and some others have against all recomendations added water.
675 watts solar
azbohunter
arizona
Posted: 04/30/12 08:40pm Link  |  Print  |  Notify Moderator
smkettner,
You are right, they are 55AH and they are four years old,we use the unit about 6 or 7 months a year for the last 4 years. My thoughts were that if I am not getting the correct charge into them, it is cheaper to replace the converter than the batteries.
I think my charger may have ran a disulficition on them, they were really hot, and didn't seem to be taking a charge. Now the cases are warm but they are charging.
I was a cabinet maker by trade but a back yard mechanic by choice, but I certainly don't know a lot about some of this stuff. That's why I come here!
09FLSTC
Out West
azbohunter wrote:
I am considering upgrading my Magnatek 7355 converter to one with a smart charge feature. I am looking at INTELI-POWER 9200 SERIES CONVERTER/CHARGER - 60 AMPS here
Is 60 amp adequate? I have been running 2-12 volt AGM series 27 for some time now, am happy enough with the batteries but they get pretty hot when sitting on shore power for extended periods of time with low usage.
My biggest concern is overcharging and incorrectly charging AGM batteries.
Would love to hear from anyone with experience at this.
For the same price, you could get it from a real company with tech support and real people (Friendly too) AND probably actually have it in stock. I'd give Bestconverter a shot to help you as so many have. Fantastic tech support. www.bestconverter.com
azbohunter
arizona
Posted: 04/30/12 09:21pm Link  |  Print  |  Notify Moderator
As I said, I don't know much about this stuff, That is why I come here!
smkettner
Posted: 04/30/12 09:22pm Link  |  Print  |  Notify Moderator
Whatever the battery you have six months from now they will be better with the PD9260
09FLSTC
Out West
Posted: 04/30/12 09:54pm Link  |  Print  |  Notify Moderator
It hit me like a ton of bricks a few years ago when I was more naive than I am today! After about 20 minutes on the phone diagnosing my electrical problem (for FREE I might add) I had the nerve to ask if I could save a dollar at my local dealer. After a quick pause I felt like a total idiot and ordered right up and continue that philosophy when somebody is willing to help me like that.
pdogg
Phoenix AZ
Posted: 05/01/12 08:27am Link  |  Print  |  Notify Moderator
I just did the replacement of my 7355 with this unit.. perfect fit and easy to install.. It's a more complete kit that just the 9260..
LINK
pezvela
San Carlos, Sonora, Mexico
Posted: 05/01/12 03:02pm Link  |  Print  |  Notify Moderator
Will the same hold true for the PD4645 45 Amp Converter? It is a direct replacement for my older Magnetek 7345 and is intended to fit into the space of the 7345. I would have to find a new place for a 9000 series converter.
On the PD site, it states that the PD4645 has three voltage outputs: storage at 13.2, normal at 13.6 and boost at 14.4. If I am using AGM batts, shouldn't a charger be able to go higher than 14.4?
