BMP01550
Mass
I am new here. My parents bought a new RV and gave me there old one. It is a 86 sportscoach pathfinder 28'. It is in pretty great shape, it just needed exhaust work and the roof resealed. which brings me to this, I need to reseal the roof, but im not sure what to use because I do not know what type of roof it has. The roof has been previosly sealed with mobile home sealant(obviously not made for RV's) and is now all cracked. I know I have a leak around a vent to seal, but also would like to seal the entire roof to be safe. Does anyone have an idea of what type of roof I may have, or how to go about this? Thanks for the help in advance!
Johnworth914
USA!
You probably have ( had) a rubber roof, but who knows what the coating was.... Be careful with roof coatings, petroleum based coatings can destroy the rubber roof.
Alaska is next! Still trying to fit the pontoons to the RV so We can get to Hawaii!
BMP01550
Mass
What would your suggestion be? Should i attempt to strip the entire roof down as much as possible and start from scratch? the only place I know it leaks for now is around the vent over kitchen, water puddles there then it leaks. I could seal that then redo the entire roof this fall. The roof itself I would say has been hacked to a point, aluminum roofing tape down the edges, whatever gray mobile home roof coating, caulking around the vents, etc... The entire interior is newer including the interior cealing panels, which I beleave there was plywood in the cieling he replaced, he cannot remember now so i believe the roof is worth repairing if it needed full replacement.
Patrol 65
Charleston, SC
I used to own an 84 Sportscoach Pathfinder 30 footer and it had an aluminum roof.
Nathan and Linda
KF4GYL
2000 Winnebago Chieftain 35U Ford Triton V10 F53 Banks Power Pack
BMP01550
Mass
Well I guess im hoping it is an aluminum roof. Im wanting to catch an RV dealer in my travels this week and grab some eternabond or proflex, but I cant get to the rv until this weekend to actually check it out, I prob should remove a roof vent and try to determine what I have for a roof. Thanks for the help.
kcstepp1992
Indiana
BMP
Check local roofing outlets as well. I get my eternabond from one that is 15 minutes away from me. Beats the heck out of driving 90 minutes to the rv store. Also if you do have a rubber roof look for Liquid Roof to do the repair work. I just bought a 4 gallon bucket and am waiting on the weather to cooperate so I can get the rest of my prep work done for the roof so it can be applied.
Traveling Langille
Plattsburgh,NY
I had a 1985 Coachman Pathfinder, It had a aluminium Roof.
Wilma 1997 Fleetwood Flair
BMP01550
Mass
Im hoping for nice weather saturday so I can get up there and really check it out, work keeps me to busy during the week, thankfully I get by the RV dealer almost daily for work (Truck Driver). I appreciate the help from everyone, I deff like this site and plan on spending more time here!
grousehunter 61
pollock idaho
I have a Sportcoach Crosscountry and it has an all aluminum roof, I think you will find yours has one too. If thats the case, unless its been damaged, all you need is to seal around the edges- vent pipes- and front and rear caps.
Rodger & Teri
1985 Sportcoach / crosscountry
1983 Camaro / 1971 Chevy 4x4
chessie's named sonny & choc and a red setter named star
http://sportcoach.blogspot.com/
BMP01550
Mass
Good to hear! I am going to pull all the old caulking and reseal it and hopefully be good to go! looked aluminum to me when I got up there the other day!
