RV.Net Open Roads Forum: General RVing Issues: Ear tabs broken
 > Ear tabs broken
sparkmechanic
SE Oklahoma
Posted: 04/30/12 07:05pm Link  |  Print  |  Notify Moderator
Looking for a simple fix for broken ear tabs on the tank drain hook-up. The 2 little nubs were broken when I bought it a few years ago, now I am finally going to fix it. Any ideas on where to find a slip fitting or something of the sort. Bob
2003 Dutchmen Sport 25
2006 Dutchmen 29Q Bunkhouse
Urban Assault Wagon K1500 Suburban +everything
F350 Utility (Dragin' Wagon) 460ci, 4.10:1 rd
Jim Shoe
Amelia, OH
Posted: 04/30/12 09:59pm Link  |  Print  |  Notify Moderator
I'm assuming that you're talking about the nubs that the sewer hose attaches to when you're ready to dump the tanks? If that's the case, I'd first measure the opening on the sewer hose hooks. Then try to find a piece of metal tubing with the same OD as the opening on the hose hooks. Cut a couple of 1" long pieces. Then get a couple of bolts that match the inside diameter of the tubes and run a bolt thru each one. Drill a couple of holes in the sewer outlet the size of the bolts, stick them thru the holes and add a nut and lock washer on the end of the bolts. Fasten the hose on the new nubs, pull the handle and pray!
The consequences of this NOT working would make me take it to a shop and have them replace that portion of the sewer outlet to begin with. Or at least train a pet monkey to run in there and close the handle. Take pictures.
Retired and visiting as much of this beautiful country as I can.
Wes Tausend
Bismarck, ND
Posted: 04/30/12 10:17pm Link  |  Print  |  Notify Moderator
I wonder if a portion of a new fitting that has the ears might not glue inside what is left of the broken one. I think common PVC black pipe glue should work if the new piece is a lucky slip-fit.
I don't blame you for avoiding major replacement, but the assembly must easily come apart from the slide valve outward. This would be the proper repair with all new parts.
Here is what a replacement kit may look like:
These sell for under $40.
Wes
Days spent camping are not subtracted from one's total.
- 2000 Excursion V-10 - 2004 Cougar Keystone M-294 RLS, 6140# tare
- Hensley Arrow - Champion 4000w/3500w gen
- Linda, Wes and Quincy the Standard Brown Poodle
hershey
Albuquerque,(fulltime) NM, USA
Posted: 04/30/12 10:23pm Link  |  Print  |  Notify Moderator
Just bite the bullet and replace it. This is a situation that if your Micky-Mouse fix fails, your gonna really regret it.
hershey - albuquerque, nm
Someday Finally Got Here
Superman was an illegal alien.
NASCAR 14 - 99
wny_pat
Western NYS
Posted: 04/30/12 10:54pm Link  |  Print  |  Notify Moderator
Just buy a Valterra Bladex Valve with metal handle. They make replacements. They bolt on or glue on - which ever. Visit a RV store!!! Simple fix and you don't need to worry about a spill!!!
JJBIRISH
Butler, PA, USA
Posted: 04/30/12 10:58pm Link  |  Print  |  Notify Moderator
click
3" Bayonet x 3" Slip Hub termination adapter...
any RV shop should have them on stock...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
sparkmechanic
SE Oklahoma
Posted: 05/01/12 04:11pm Link  |  Print  |  Notify Moderator
JJBirisch, that is exactly wht I was looking for, next is a FloJet kit and some hose and it is game on. Thanks all. Bob
smokedummy
McLennan County Texas
Posted: 05/01/12 10:34am Link  |  Print  |  Notify Moderator
Maybe drill holes and put in a short stainless steel bolt each side?
travel pics etc
2012 Skyline Mountain View Retro 140, 16'.
Kennedycamper
Algoa, Texas
Posted: 05/01/12 10:39am Link  |  Print  |  Notify Moderator
I like the short stainless bolt on each side idea. Use a washer too to help spread the load on the plastic.
JJBIRISH
Butler, PA, USA
Posted: 05/01/12 11:58am Link  |  Print  |  Notify Moderator
It is really just to easy to cut the old one off and replace it and do it the right… the part is all of $3, and they don‘t go bad or get broken very often…..
 > Ear tabs broken
