RV.Net Open Roads Forum: Class B - Camping Van Conversions: AC on top
RonAllen
SouthFlorida moving to Pensacola,FL
Posted: 04/30/12 07:19pm Link  |  Print  |  Notify Moderator
Have been looking at some High-Top conversion vans. Is there a way to put an AC on top without damaging the top? Is a standard RV AC OK?
Ron
Retired USN SMC
2003 Dolphin LX 36' 8.1
c.traveler2
Moreno Valley,Ca.
Posted: 04/30/12 10:45pm Link  |  Print  |  Notify Moderator
If you have a 14"x14" vent it can be installed there and a small unit doesn't weight all that much, 90 to 120 pounds for a small unit.You'll just have to figure out how to power it.
Dometic AC
Coleman AC
Polar Cub AC
2007 F-250 4x4 /6.0 PSD/ext cab/LB/camper pkg..Lance 815/ 85 watts solar panel
Travelingman2 Photo Website
Truck Camper Trip Reports
My Roadtrek
Tucson, AZ.
Posted: 05/01/12 12:53am Link  |  Print  |  Notify Moderator
You will have to figure out a way to install it on the roof without walking, kneeling, etc. on the roof. Most are too thin to hold ones weight. You will have to reinforce the area where the AC will go, and of course get it wired up. You will need something around 11,000 btu's or more, and only expect about 10 to 15 degrees max of cooling.
georgelesley
Minnesota
Posted: 05/01/12 01:53pm Link  |  Print  |  Notify Moderator
I would also be concerned about the noise the unit makes in a small metal van. I just did this on our American Cruiser class "B", a bigger and likely more sound muffling than what you are talking about, and the sound when it operates is loud, but OK with us, just beware. I agree you will have to reinforce the roof in the area of the install, the good news is that as stated above any standard RV vent hole should work. Snaking a 12 gauge wire to power it may be your biggest challenge.
George & Lesley
2013 Winnebago ERA 70A
gerrym51
unknown
Posted: 05/01/12 02:17pm Link  |  Print  |  Notify Moderator
sportsmobile has a special underfloor air conditioning unit. it is not cheap.
gerrym51
unknown
Posted: 05/01/12 02:19pm Link  |  Print  |  Notify Moderator
rodger, did you get your airstream yet
